Leaf Spring Bolts
Old Jun 10, 2018 | 02:27 PM
JensenF250's Avatar
JensenF250
Found ones at AutoZone for a Dana 60, 30 spline. Mile Marker brand. Would like to hear your thoughts.
Old Jun 10, 2018 | 02:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Correct u-bolts used on 1967/72 F250 4WD with Dana 60 and F350 with Dana 70. Specs in post #11.
Old Jun 11, 2018 | 08:25 PM
fe390pc's Avatar
fe390pc
Jensen, that is a very strange set-up for a 4x4. The ones I have seen have a 4" block between the axle and spring in the rear. What front axle do you have? Is it open or closed knuckle?
Old Jun 20, 2018 | 07:51 PM
JEFFFAFA's Avatar
JEFFFAFA
C7TZ-5705-A .. U-Bolt / Obsolete
1967/72 F250 4WD & F350 // Pic: C7TZ-5705-A specs: Column left, 5th entry.
GREEN SALES CO. in Cincinnati OH has 19 = 800-543-4959.
WHOA horse. C7TZ5705A is much too long. OP needs part number B3D5705A.
Old Jun 20, 2018 | 08:11 PM
JensenF250's Avatar
JensenF250
Thanks. Bought them and they really were waay too long. I had them cut down and welded. Had them welded side by side and they fit snuggly and worked. Just ugly looking.
Old Jun 20, 2018 | 08:18 PM
JensenF250's Avatar
JensenF250
Closed knuckle. 12 bolt. 44HD. Believe it's 3500 but not sure - can't find a tag..
Old Jun 25, 2020 | 04:58 PM
JensenF250's Avatar
JensenF250
Hi all - wanted to check and see if someone has a part sheet for u bolts size on the fronts.
Also wanting to get some shackles for the read springs. Looks like a joker welded the bolts on and we’ll need to cut them off.
Would appreciate any help on identifying these parts.
Thx!
Old Jun 25, 2020 | 11:36 PM
stpackard's Avatar
stpackard
I bought ubolts and springs bolts/nuts from general springs kc. They had the HD and LD springs available and had all this stuff too. There were some front rear upper shackle bolts they didn’t have a measurement on so I went to NAPA and found some in their grade 8 bolt bins. I think they ended up being the same size as the front rear lower bolts.
BGF100
Sep 1, 2015 07:16 AM
octaneforce
Aug 22, 2011 06:13 PM
TxFireman1972
Apr 6, 2011 07:04 PM
tommyleea
Bronco II
Jul 7, 2009 07:19 AM
bill1958
May 7, 2005 09:54 PM
