Rear leaf springs
Old Apr 18, 2005 | 10:36 PM
bill1958's Avatar
bill1958
Rear leaf springs
Any ideas out there on how to remove the leaf spring shackle bolts without trashing the bushings?
Old Apr 19, 2005 | 07:52 PM
Steve's Beast's Avatar
Steve's Beast
A 4" zip-cut disk with a angle grinder works well. But you will need new bolts.
Or some good penitrating oil, but if they are like mine penitrating oil is not an option.
Hope is helps!
Steve
Old Apr 19, 2005 | 08:56 PM
CdnFord Eh's Avatar
CdnFord Eh
When I did mine, I hack sawed between the spring and shackle. Alot faster and easier than fighting to get them loose. Chance are you'll need new bolts anyways.
Old Apr 22, 2005 | 09:08 PM
Chiefrider007's Avatar
Chiefrider007
I've had good luck using a big air wrench. Tap on the back side lightly and turn away.
Old Apr 22, 2005 | 09:44 PM
mustange70's Avatar
mustange70
also if youheat the metal up with a propane tourch it can help, but an air grinder is the best.
Old May 7, 2005 | 09:54 PM
krash51218's Avatar
krash51218
torch
I used the propane torch technique myself along with penetrating oil
