71 f100 split side rust help
Old Jun 23, 2020 | 11:27 AM
tyrale's Avatar
tyrale
I’m currently trying to grind out the rest between the bed panels down the exterior. Any tips on getting deep in that scene. I can’t seem to get the last of it out.
Old Jun 23, 2020 | 02:16 PM
jzjames's Avatar
jzjames
FWIW, I take a hacksaw blade and cut it in half, then I use the half-blade to “rip” out the rust in the seam. (Be sure the teeth are going in the right direction) (probably use gloves).
This will get into that crevice pretty well, and at least pull out most of the scaley rust. From there you can treat the rust in your favorite way.
Sandblast, chemicals, just remember there is an entry point for moisture on the back side of those seams. Also I wouldnt use Por15. Dont like it, doesnt last.
Old Jun 23, 2020 | 02:25 PM
tyrale's Avatar
tyrale
thanks. I’m borrowing a sand blaster. Hope that will get it.
Old Jun 24, 2020 | 10:17 PM
stpackard's Avatar
stpackard
Maybe tape the paint you don’t want to blast and surgically sand blast the seam. I did this on mine. I was persnickety on paint prep, then used por15, and por15 patch. I left that stuff low then used seam sealer to level it. Then primed, blended, sanded in to the top coat. I shot the por at the underside of the bed seam.
I Also did this process on the drip rails, I didn’t want water sitting in those welds underneath cracked seam sealer. I wanted the original paint on mine. I used a sonicrafter in some places. This job is a pain.
i would have used the masterseries rust paint if I did it again. Stay away from por15 gloss, nothing sticks to it.
Old Jun 25, 2020 | 06:54 PM
LACzar's Avatar
LACzar
Have you used the master series rust paint on other projects? I was planning to use on mine. How do you like it? _ Tony.
Old Jun 26, 2020 | 12:16 AM
stpackard's Avatar
stpackard
Masterseries seems to be holding up pretty well, not pealing or doing anything funny. I think it’s good for areas where you can’t clean out 100%. I’ve seen guys on forums take their bed apart at the seems to get every last rust spot. Master series seems to bond tightly, chemically and physically I believe. They make a sprayable version. It sands well, which helps alot.
I don’t mess with taking the lid off. I stab the top lid and squeeze out what’s needed after shaking/stirring. I can’t say for sure, it’s moisture cured, reducer can be added, but it’s not two part. I don’t know if this helps but I’ve had success using it.
Mike8623
Mar 21, 2020 11:12 AM
ek9beezler
Jan 10, 2016 11:36 AM
loudoun
Jul 16, 2014 12:22 AM
nmclella
Nov 3, 2013 01:46 PM
Km1210
Aug 12, 2012 06:52 AM
