removing leaf springs
Old Aug 21, 2011 | 02:34 PM
octaneforce's Avatar
octaneforce
i went to replace my leaf springs today but i ended up putting everything back together. i had no problem getting the nuts off the bolts that hold the pack to the hangers, but i could not get those bolts to move! they are really seized into the bushings. i fought with them for hours and gave up. what is the best method to do this? i am thinking about just cutting the bolts out next time, which is why i stopped. i want to get all the hardware ready if i do that. my next idea was to heat up the shackles/hangers, but the driver side leaf spring is right next to my front gas tank. i need tips! i did not think those bolts would be an issue. i have been soaking them in wd40 for a week.
Old Aug 21, 2011 | 05:18 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You're on the right track.
When the rust starts to scale they just get tighter and tighter in the bushings.
No amount of lubricant is going to dissolve the rust that's putting pressure on them, nor will it smooth out the -now- rough, gripping surface.
Best to get new bolts and bushings, cut the old ones inside the shackle with an .045 disc or a sawzall and drive them out with a punch and a 4lb hammer on the bench.
Old Aug 21, 2011 | 06:36 PM
octaneforce
okay so i guess im not crazy lol. while i was doing this, i realized that the bracket that the rear of the leafsprng sits on was very rusted and thin. what is this part called? the shackle? its a peice between the spring and the hanger at the rear of the truck. where can i get just this? my hangers are fine but that particular bracket is on its way out.
Old Aug 21, 2011 | 06:43 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
This is for the '92 F150 in your sig?
Dorman OE Solutions has them in the aftermarket so any auto parts store should be able to get them from a regional warehouse.
I think you'd be looking at the 722-004, Ford #E0TZ-5776-A
Dorman Products - Leaf Spring Shackles & Brackets
Old Aug 21, 2011 | 06:49 PM
White 97 xlt's Avatar
White 97 xlt
Now, THAT is service with a smile!!!! You are smiling aren't you?
Old Aug 21, 2011 | 07:22 PM
Bankrupter's Avatar
Bankrupter
I had to do this today doing my spring hangers. Sawzalled the bolt head and nut out of the shackle on the inside edge then burned then out the bushing with the torch and pushed them out with a punch by hand. I got a full kit for 120 shipped. Two hangers twos shackles all hardware needed in one box... could not get better then that. Had to get two bushings for the spring eyes though do to your issue here...
I used ATS: http://www.autoandtrucksprings.com/p...-1336-155.html
Thats the full kit but they got what you need too. 21 bucks I think
Old Aug 22, 2011 | 06:13 PM
octaneforce
wow thanks for all the info! il be able to get everything i need
themdgx
1983 - 2012 Ranger & B-Series
13
Dec 16, 2012 10:21 AM
tommyleea
Bronco II
Jul 7, 2009 07:19 AM
Pnutman
Aug 4, 2005 08:30 PM
bill1958
May 7, 2005 09:54 PM
Stanstruck
Oct 28, 2004 07:16 PM
