EGR or Head Gaskets?
First- some background on the truck: I bought it from original owner in December. He had Bulletproof EGR installed within about 50 miles of noticing some overheating issues. I'm not sure if he ever had that shop check head gaskets or anything else. He was an elderly gent who generally took very good care of it.
Now on to my problems--- a few weeks ago when we started to first hit triple digit temps here, I noticed the EOT and ECT (using SCTx4) were a bit higher than usual without load (EOT ~220; ECT ~200). Shortly after that I took the 6000 lb camping trailer for a short weekend temp. Outside temps were just under 100- I noticed the EOT was pushing 250-260 on a grade and ECT was staying between 195-210. Luckily it wasn't too far from the camping spot so we were able to park it for the night. The next afternoon on the way home I made sure to drive it easy- we were only camping 30 minutes away- and all the temps were about the same.
I had Ford dealership check it out, and the tech pulled the EGR valve, noticed it was a bit gooey, and revved the engine with valve off. He said it was spraying some fluid out of the EGR valve onto the inside of the hood so this meant the EGR cooler was bad, and figured with the huge temp differences that oil cooler is definitely shot.. I explained it has a Bulletproof EGR so I doubt it would have failed, but he seemed pretty confident that it failed with the gooey valve. He said he would like to check if the head gaskets were holding pressure but won't be able to until the EGR is replaced. He noticed the Degas bottle has a bunch of hairline cracks along the seam, and there is some obvious spots where fluid is escaping- however I haven't noticed any loss of coolant. It's been at the min. line for about 5-600 miles that I've been monitoring it. So of course the quote he gave to flush, replace Degas bottle, oil cooler and EGR was about $3500, and to do head studs and gaskets on top of that would take the total to almost $6k. Luckily I'm friends with the service manager so he was able to work that down to $2200 and $4200, respectively. However I don't have that kind of cash and we need the truck a lot this summer. I have another friend that's a diesel tech for a landscaping company and has done a ton of work on their 6.0's so he quoted me around $650 for labor. So-- I called Bulletproof Diesel and the tech I spoke to on the phone said that if I'm not losing about a gallon of coolant every hundred or so miles, then he's pretty certain the EGR has not failed, and that only about 1 out of 10 of the EGR's that are returned to them for warranty have actually failed. He also explained that from his experience a gooey EGR valve doesn't necessarily mean failed EGR- there could be other sources of moisture causing that. He explained all this saying that I could pressure test it myself when its out of the truck, and he'd hate for me to buy a new EGR when that one hasn't really failed. Ah I forgot to mention earlier that I have never seen any white smoke since I bought it. I even did a cold overnight start before I bought it- no smoke ever. The only thing suspicious with the exhaust is that there is a slight coolant/ sweet smell from the exhaust.
That all being said, my friend is going to start working on it tomorrow in his shop, but wants to do a compression test on the heads before he gets into anything else just to make sure the head gaskets haven't failed. I've seen Bulletproof Diesel's youtube video about using the water bubble test to determine is EGR or head gaskets have failed, but I don't know if I trust it just cuz it seems to simple. So, if he's going to do the compression test by pulling the glow plugs, is there any other way to check for head gasket issues? I've also attached some pics of what my engine bay looked like this morning- oil doesn't seem milky, coolant seems normal... Please let me know what you all think.
(and the ford guy is most likely right - if fluid is spraying out of the EGR valve hole in the intake with the valve removed - it's coming from the EGR cooler. that's a far cry from just a gooey egr. and coolant smell in the exhaust would bring me to tears)
(and I'll be shocked if your head gaskets aren't blown too)
subscribed.
My new oem thermostat has my ect between 192-198 unloaded (my eot runs 10-12° above ect), so your ect seems ok. Coolant smell in exhaust would concern me, but I'd hate for you to replace the hg's unless needed. My oem degaus tank was starting to form hairline cracks at the bottom of the tank after ~130k miles so I changed it out when my radiator blew an end tank seal a few weeks ago. How does it run? I am leaning towards a clogged oil cooler if it runs well and you aren't pushing coolant out the cap.
The new oem thermostat has my ect between 192-198 unloaded (eot is 10-12° above ect), so your ect seems ok. Coolant smell in exhaust would concern me, but I'd hate for you to replace the hg's unless needed. How does it run?
And the Ford tech smelled the exhaust- since it was so faint he didn’t seem to think too much of it. But he did give me the standard “don’t drive it far” speech.
Is your EGR cooler actually a Bulletproof Diesel version? Plenty of eBay versions claiming the name but may not have the history to back it up.
I would agree the EGR cooler and your oil cooler have issues at a minimum.
But the other comment that was made about it not having been flushed before it was installed- that’s entirely possible. There’s a reason I don’t go to that shop, even though the tech is really skilled. (Lazy)
Likely caught in time before the heads lifted.
Is there a definitive way to test the integrity of the head gaskets without actually pulling the heads? The Ford tech said he can check it but the EGR has to be in place and good, the other guy said he can do a compression test, but I've also heard that won't actually work, and I've seen the bubble test on youtube.... Anyone know of anything?
https://www.bulletproofdiesel.com/Bu.../nt-egrc-1.htm
