EOT/ECT temps when towing a load
Old Jun 3, 2018 | 07:17 PM
bismic's Avatar
bismic
First task would be to get the coolant temps down when towing. Then I would worry about the oil cooler issue.
Thermostats are easy to change, I would start there. Lots of people have had issues with the OEM thermostat. I am not a big fan of the Mishimoto thermostats, but some folks really like them. Some people use Stant, and I am going to switch to a Gates thermostat (Rock Auto) soon. I am not happy with my OEM one.
You need to know what coolant you are using. The wrong coolant can cause big problems. The recommended coolant is certainly NOT the OEM Frod Gold or it's GO5 equivalent. You need to be running a CAT EC-1 rated ELC coolant. To switch, you need to THOROUGHLY flush the old coolant out (final 2-3 flushes being w/ distilled water, or better yet, ALL the flushes w/ distilled water) and then after the very last drain, add 3.5 gallons of concentrated coolant. You finish by topping off with distilled water. That way you get a 50/50 mix - which is very important.
Old Jun 3, 2018 | 07:19 PM
bismic's Avatar
bismic
Originally Posted by texastech_diesel
Yes, fueling is reduced to try to hold back engine temps at ECT over 221*, EOT over 253*. Mark asked about the fan because multiple factors can trip 100% fan clutch engagement, and EOT being high enough is one of those.
Mark - page 1-33 is the 221*ECT/253*EOT derating language (second pic), the first pic is from a chart on 3-11 as part of the pinpoint tests of concern of "engine down on power with no CEL". I wanted to type 235 for oil but that seemed wrong, I searched in the wrong book and 260* popped up. Weird.
Bryan -
My 2006 PC/ED does not have those higher values in Section 3. In fact it doesn't actually list the defuel values in that section.
Additionally, the injector contribution tests must be done w/ oil temps at or below 246*F which leads me to believe the 253*F defuel point.
Which year PC/ED manual are you using?
Old Jun 3, 2018 | 07:21 PM
IABill's Avatar
IABill
Dustin, My rig in sig line towing my 12K Heartland Cyclone 35 foot toy hauler 98 degrees, A/C blasting last Sunday. Highest coolant temp 212 Highest oil temp 219.(torque Pro) Pushing it from Springfield IL to DSM about 70 to 75 all the way. Now here is the disclaimer. two winters ago about 110K on the clock system chem flush and new coolant then a month later new cooler. I believe my temps are a good example of a cooling system in good shape. Stock cooler will do a fine job if not plugged IMHO.....Bill
Old Jun 3, 2018 | 07:26 PM
bismic's Avatar
bismic
I LOVE your post Bill!!
Reps and Thanks!
Old Jun 3, 2018 | 09:26 PM
wedge542's Avatar
wedge542
what kinda fan clutch you got? do you ever hear the fan roar at all?
Old Jun 3, 2018 | 09:42 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
2007 - Print date 11/2006. We might just be seeing high/low values; fuel derating for ECT starts at 221 per Sec 1 and ramps up to noticeable power loss at 235* per Sec 3; the point of that pinpoint test is low power with no CEL, so ECT and EOT maximum derating would be a concern they'd have to check for.
Old Jun 3, 2018 | 09:45 PM
texastech_diesel
Token Redneck
Originally Posted by Dustin Yates
UGH!
Would adding the external oil cooler help?
Yes it should. The BPD system completely splits oil cooling separate from coolant to a plate cooler in the radiator stack. Expensive (and IMO not necessary since a correctly functioning stock system should be fine for any 6.0), but it's a permanent solution:
https://www.bulletproofdiesel.com/bu...heavy-duty.htm
Old Jun 4, 2018 | 12:08 AM
IHateCommieCars's Avatar
IHateCommieCars
I just finished flushing my shuttle bus and refilling with G05. Now I'm reading that's not good??? And all my other trucks have that as well. Arrgh.
My truck delta is usually 10-18, but it seems to cool down quickly, and I'm almost always pulling a trailer, plus the one I drive most is an F450 with a heavy flatbed with tool boxes, so I've assumed my higher deltas are OK. Not great, but OK.
I was going to post about my shuttle bus though. I've only had it out a few times since I got it shipshape, only once on the freeway. It got up to 222 just cruising along about 60. It is hot as heck here, and I think Eseries run hotter. The delta was 10-12. But, it has me a bit worried because I was hoping to tow 5000-7000lbs with it once I get a hitch installed. I see E450 RVs pulling cars, and I'm thinking those weigh more than my shuttle. Do y'all think I can do it? Does it sound like it's working right?
Old Jun 4, 2018 | 09:17 AM
IABill's Avatar
IABill
Thanks Mark, Wedge still running stock original fan clutch, and I forgot to mention rad is only about two years old as well it's the third one as the previous two were replaced due to Deer hits prior to the cooler and cooling system service it would do it usually after a long hill pull. Since the service I have maybe heard it roar two or three times......Bill.
Old Jun 5, 2018 | 02:16 PM
Excurvelle's Avatar
Excurvelle
When I had an external IPR my temps were the same as they are now, I went back with the internal cooler. 10-11 not towing 12-15 towing.
efiguero
Sep 26, 2018 12:39 PM
Mike in Arizona
Apr 29, 2018 08:27 PM
Bigfoot76
May 7, 2013 11:34 PM
DawnPatrol
Mar 7, 2013 08:47 PM
Rockledge
All Things Towing
Jun 12, 2004 11:07 AM
