power door lock issue
Old Jun 1, 2018 | 09:11 PM
frenchie9's Avatar
frenchie9
Hi my 1998 conversion van (from starcraft) since I own this van (3 years) and always had intermittent problems with my power lock doors. Here's the problem in detail. When it's not working it's always the same, the problem is on all 4 doors. All the time, never had a time when only one door wasn'nt working. Something new lately, 100% not working now, and also noticed when attempting to use door lock button (ether door side) the roof light will light up ! Just like if the door lock switch was the roof light switch. I made a few checks, but my knowlage is limited. Thank you for your help
Old Jun 5, 2018 | 04:12 PM
maples01's Avatar
maples01
The current travels through in series, I suspect corrosion, the one in my rear door is responsible for this, I take it out, bang it on the bumper and after reinstall it's good for a little while longer, the switches aren't cheap, but you can try replacing them, ceiling light issue could be a bad ground.
Old Jun 5, 2018 | 09:19 PM
frenchie9's Avatar
frenchie9
Thank you maple, corrosion could be, indeed a possible cause, as this van had lots of corroded connectors, wire...and body when I purchased it. I will take a look at the rear door. Thank you for your reply.
Paddy1998
Jun 6, 2018 08:45 PM
Bad News
May 7, 2018 07:25 AM
aerostargal
Aerostar
Aug 15, 2004 11:31 AM
Cardude_mad
Aerostar
Jul 12, 2004 03:24 PM
ray_te
Aerostar
Jul 12, 2004 12:27 PM
