2000 Ranger Brakes
Old Jun 1, 2018 | 04:50 PM
HillBillyBuddha's Avatar
HillBillyBuddha
2000 Ranger Brakes
Few months back, i was running errands. Pulled out of a parking lot and my brakes went out. Pedal went straight to the floor without resistance. Pumping didn't work. And the weren't any warning signs before it happened. I had changed the pads, maybe 3 or 4 months prior to this happening but I rarely use the truck. So I think I probably driven it a total of 12 to 18 times between changing the pads and the brakes failing. Guess I should say, front and rear brakes went out but parking brake worked well enough to stop me at low stres speeds.
After the tow home, I pulled the wheels and everything looked fine. Pads have meat, the rotors are good enough although I figured I'd have to replace them during the next brake job, the master cylinder resivoir is full, no brake fluid dripping or squirting from anywhere that I can see.
Pedal goes to floor without resistance and slowly returns to the "up" position with the engine running. With the engine off, there's a lot of resistance on the pedal.
What ami missing?
Old Jun 2, 2018 | 07:04 AM
Dan Robertson's Avatar
Dan Robertson
Does the peddle go to the floor with the engine not running? If you have a full reservoir and no leaks I am leaning towards a master cylinder or vacuum booster issue.
Old Jun 2, 2018 | 07:26 AM
john jamieson's Avatar
john jamieson
sounds like when my booster went out. With the engine running, step on the brake pedal. Do you here an air sucking sound?
Check the hose that connects the engine to the booster and make sure it isn't broken or become disconnected.
Old Jun 2, 2018 | 12:42 PM
HillBillyBuddha
With the engine off the pedal does go all the way to the floor but there is a lot of resistance.
With the engine on, there's a hissing sound. It's probably caused by suction but it's clearly hissing.
I'm guessing, since the front and rear went out at the same time, I should be looking at the booster and master. I'll pull those today (probably... it's suppose to be 97 degrees today so I might just stay inside) and report back.
Old Jun 2, 2018 | 10:57 PM
HillBillyBuddha
Ok. My wife was home today so I had her sit in the truck while I was under the hood.
With the engine off, I had her press the brake pedal. The hissing sound came from the top of the reservoir. The reservoir also bubbled and almost overflowed. The cap was on the reservoir. Took the cap off and had her press again. Hissing sound was gone but the reservoir still bubbled up and almost overflowed.
Next I wanted to see if there was any brake fluid pressure at the caliper. I loosened the bleed valve and had her press the pedal. Oil flowef out but without much prrssure. Didn't squirt like when I'm bleeding brakes. Nor was its a constant flow. I'm guessing I'll need a master cylinder?
What do you guys think?
Old Jun 27, 2018 | 04:55 PM
HillBillyBuddha
I finally got around to changing the master cylinder and reservoir. Still don't have any pressure at the brake pedal. Still can't find any leaks and the reservoir isn't losing any oil. I noticed the brake lines go into an electric pump thing. After some research, it seems my truck is equipped with abs, although, I'm sure it must have been disconnected at some point before i bought it because ive never felt the ABS engage. Anyway, is it possible that the pressure leak is somewhere in the EHCU and can it be bypassed? I have read its almost impossible for a DYI'er to bleed the system with this unit.
Old Jul 10, 2018 | 07:57 PM
Tanntheman's Avatar
Tanntheman
Booster
But if it was a booster he would still have breaks it would just be manual breaks wouldn't it cause there is still a physical connection to master cylinder form the pedal
Old Jul 10, 2018 | 08:28 PM
HillBillyBuddha
Just an update. I bypassed the ABS and I've got brakes again.
Old Jul 23, 2018 | 11:11 AM
Thurman Rigsby Jr's Avatar
Thurman Rigsby Jr
BRAKES
I WOULD BLEED THEM DOWN FIRST
Old Jul 23, 2018 | 11:13 AM
Thurman Rigsby Jr
MY REAR WHEEL ON DRIVERS SIDE IS STUCK. BUT ONLY IN REVERSE SPINS FINE WHEN IN AIR PADS, SLAVE CYLINDER, STAR ADJUSTER AND SPRINGS LOOK GOOD. AS SOON AS I DROP IIT ON THE GROUND LOCK UP. 3 TIMES
Old Jul 23, 2018 | 11:17 AM
Thurman Rigsby Jr
NEED A JACUZZII AFTER BRAKE WORK, WOOD CUTTING AND OTHER
Old Aug 8, 2018 | 01:01 PM
Tommy Patterson's Avatar
Tommy Patterson
I I have a 2000 Ranger also mine did the mine it was the rubber diaphragm in the top was not stealing and my lid expanded from too much heat and pressure so wasn't fitting correctly I just replace them both and it's been fine since
carchub
May 15, 2015 12:30 PM
Mearle
13
Jan 24, 2014 10:26 PM
jon1
Bronco II
Jun 25, 2008 01:59 PM
Thomas A
Oct 25, 2005 03:42 PM
f100beatertruck
May 25, 2003 11:09 PM
