brakes lockup when engine is started
Old Feb 9, 2012 | 02:43 PM
Mearle's Avatar
Mearle
Question brakes lockup when engine is started
I have a 1987 f150 5L 4wd pickup.
The front passenger disc brake was locking up initially and looked rusty so I replaced both front calipers and pads. Everything OK for first spin around the block. then did emergency stop and brakes locked up and stayed locked. Bled brakes & drove home using emergency brake.
Pulled front wheels. Rotors spun. Started engine and watched the brake pedal depress by itself. checked rotors and they stayed locked as long as the engine was running.
I searched some for related posts & tried loosening the master cylinder from the booster 1/4".The brake pedal dropped again and brakes still locked when engine was started.
Does anyone know what is going on and how to fix it?
Thanks
Old Feb 9, 2012 | 03:11 PM
White 97 xlt's Avatar
White 97 xlt
Sounds like the vacuum booster crapped out on you.. Remove the vacuum hose from the booster and plug the hose and start the truck, if it is a bad booster it should not apply the brakes..
Old Feb 9, 2012 | 03:13 PM
White 97 xlt
BTW Welcome to FTE....
Old Feb 9, 2012 | 04:35 PM
Mearle's Avatar
Mearle
Thanks for the welcome, I've always been able to find the answers before just by searching, so didn't register.
I blockd vac, started truck - pedal did not depress. removed master cylinder attached vac and rod came out of booster about 3 inches.
will replace
thanks
Old Feb 9, 2012 | 04:37 PM
SCRebel's Avatar
SCRebel
Now would be a great time for a brake booster upgrade. just a suggestion.
Old Feb 9, 2012 | 04:49 PM
bashby's Avatar
bashby
I believe you are talking about hydroboost.? (Just in case the OP wants to search the subject, or maybe someone will supply a link)
Old Feb 9, 2012 | 05:22 PM
SCRebel's Avatar
SCRebel
That would be a good idea. But I am talking about a F350 booster/master cylinder. Like a booster/Master cylinder for a f350 with a 351w.
Old Feb 9, 2012 | 06:46 PM
Mearle's Avatar
Mearle
SCRebel,
Would that be a straight forward swap, or require other changes? Which production years would work?
Thanks for the suggestion.
Old Feb 9, 2012 | 07:37 PM
SCRebel's Avatar
SCRebel
There is two different type of boosters. I believe the shafts are different. Just make sure the get a f350 Booster that where the shaft that connects to your brake pedal is the same.
Its a straight forward swap. Just keep in mind it will take up more room. Also recommend f350 drum cylinders, and bigger calipers. But the booster and mater cylinder will make a great difference.
I am not sure about the years. I would get one for a 88-91. Same body style and everything was EFI in 1988.
The bigger calipers and cylinders will also make a big difference after the f350 booster/master cylinder.
Old Jan 24, 2014 | 12:30 PM
vreed12397's Avatar
vreed12397
Guys, I recently replaced the booster on my 87 F150, 4X4, standard trans, 302 and the brakes are "spungy". I blead the brakes (may need to do again??) but the front brakes dont seem to be doing much. The pedal pushes in a long ways before any braking happens and now the right rear lcoks up (drum).
Any suggestions
Thanks
Van
Old Jan 24, 2014 | 08:30 PM
blkF250HD's Avatar
blkF250HD
Any suggestions
Thanks
Van
Was there fluid in/on the booster? And did you bleed the front and rear brakes? If theres fluid in the booster or on the front where the MC bolts up you have a leaking MC.
Old Jan 24, 2014 | 08:37 PM
Monteg0's Avatar
Monteg0
Any suggestions
Thanks
Van
Why did you dig up a 2 year old thread instead of starting your own?
Old Jan 24, 2014 | 10:17 PM
vreed12397's Avatar
vreed12397
I don't see the tab for "New Thread". Perhaps I dont have permissions yet??
Old Jan 24, 2014 | 10:26 PM
vreed12397's Avatar
vreed12397
brakes spongy
I did notice a little dampness around the booster below the MC today. It may be time for a master cylinder
HillBillyBuddha
1983 - 2012 Ranger & B-Series
Aug 8, 2018 01:01 PM
Hawkmcgee
Aug 26, 2014 08:07 PM
71LTD390
Nov 16, 2007 12:27 PM
coletrain777
Sep 21, 2007 08:27 PM
thefuzz472
Jul 30, 2007 04:08 PM
