Softening the Ride
Old May 26, 2018 | 09:07 AM
Toddo30's Avatar
Toddo30
Softening the Ride
Hi, is there any way to "do something" to the suspension to make an F-150 ride better, like an Avalanche? TNX
Old May 26, 2018 | 09:53 AM
scott91370's Avatar
scott91370
Buy an avalanche? I can tell you my truck rides better than my neighbors avalanche ever did.
Or, a Cadillac. It is a truck, meant to do truck things which require a slightly more firm suspension, Part of that means you're going to get a truck like ride.
Old May 26, 2018 | 10:11 AM
Toddo30's Avatar
Toddo30
Obvious things aside, like, yeah I know it's a truck, but what do they do to the Expedition that makes it ride better, that can maybe be done to the F-150. I like the F-150, but being older, I would like not to rattle these here old bones around that much! :-) And if your Ford rides better than an Avalanche, you had to do something to it.....
Old May 26, 2018 | 10:26 AM
onug's Avatar
onug
Make sure you’re tires are not over inflated...that’s probably the only thing you can do without any mods. Or add some weight to the bed of the truck.
If you’re willing to spend some money, maybe Rancho’s adjustable shocks will make a difference. It’s possible the lighter settings will be softer than stock. Or if you’re running 20” rims you can downsize to 18” for more tire sidewall.
Old May 26, 2018 | 10:38 AM
MattOzzz's Avatar
MattOzzz
Put something heavy in the back. I think they ride much better with a load.
Old May 26, 2018 | 10:54 AM
CR172's Avatar
CR172
My '15 XLT rides much better then my old '07 Sierra. Avalanche???? Ick.
Old May 26, 2018 | 11:24 AM
GABAR's Avatar
GABAR
Even though the new Expedition and current generation F150 are built on the same chassis, the Expedition has something the F150 has never had and that`s an "Independent Rear Suspension".
An independent rear suspension has a much better and smoother ride than a leaf spring rear suspension but it also gives up payload and towing ability.
Old May 26, 2018 | 05:42 PM
scott91370's Avatar
scott91370
Originally Posted by GABAR
...the Expedition has something the F150 has never had and that`s an "Independent Rear Suspension".
Exactly. It's a truck not a 'luxury' vehicle - I mean for a truck it is, but in all reality it's not.
Weight does help some too. But I come from driving trucks from the 70-80's and later trucks I've owned were 3/4 ton and then sports cars, so to me the factory F-150 is awesome.
Old May 27, 2018 | 01:12 AM
JKBrad's Avatar
JKBrad
The Avalanche had coil springs in the rear and was built on a Suburban chassis. It was not a truck that was biased towards work. The Expedition has had a coil sprung independent rear suspension since ‘03.
Like was mentioned above, you can go with Rancho 9000 adjustable shocks. Also as suggested, move to 18” wheels if you currently have 20s.
You can also try these
Sulastic. Leaf Spring Shackle
Old May 27, 2018 | 01:13 AM
Juanzilla's Avatar
Juanzilla
If the truck is new, it has 40 psi in each tire. Going to the door sticker 35 lbs makes a big difference. Ride is better and i dont see an MPG change.
Also, putting something heavy in the back will help a bit, especially when the truck is new. I can tell the smoothness difference even after the weight of a full tank of gas. The rear end is really, really light.
Sand or water jugs work well.
Old May 27, 2018 | 06:39 AM
tree10's Avatar
tree10
You can see why it must be hard to manufacture trucks these days. There are pages of threads on Payload and what options to avoid to keep it high. Then there are pages asking how to make their truck have a softer ride. The two do not work well together.
zman7125
1983 - 2012 Ranger & B-Series
Sep 21, 2010 08:07 AM
omni
Jan 24, 2004 10:20 PM
Parkerco
Mar 7, 2003 09:56 AM
jherman
Dec 9, 2002 01:38 PM
77fromheaven
Feb 7, 2002 07:11 PM
