3/4 ton ride
Old Jan 21, 2004 | 11:41 PM
omni's Avatar
omni
3/4 ton ride
I'm going to look at a 1996 3/4 ton reg cab on the weekend, does anyone have any comments on theses trucks, if so let me here e'm, pro's or cons, kinda curious about the ride, I have a 1991 f1504x4, never had a 3/4 ton, are they a much rougher ride? anything I should look out for? thanks in advance
Old Jan 22, 2004 | 12:00 AM
kevinrf250's Avatar
kevinrf250
The 3/4 ton will ride quite a bit rougher than a 1/2 ton but I don't think that it is too bad.
Old Jan 22, 2004 | 12:54 AM
fordmarshall111's Avatar
fordmarshall111
it rides rough but good tires and shocks improve it alot. i got jolted around alot in mine until i replaced these a few weeks after buying it.
Old Jan 22, 2004 | 02:56 AM
MavStallion's Avatar
MavStallion
The heavier the truck, the rougher the ride it seems. My F-150 doesn't ride too bad, but there's a noticeable difference between it and the 2002 F-450 rig I use at work, even with the Air-Ride suspension in the rear. The Super Duty line seems to ride a bit harder. You gotta pay something for the extra guts.
Old Jan 22, 2004 | 03:03 AM
1990F2504X4's Avatar
1990F2504X4
the 150's have coil springs and IFS, so the ride will be fairly smooth, the 250's have leaf springs and IFS so the isnt too bad, with stock springs..
Old Jan 22, 2004 | 12:35 PM
parks911's Avatar
parks911
Me personally don't think a truck is a truck without a rough ride.
Old Jan 22, 2004 | 06:06 PM
turn8's Avatar
turn8
I have '96 3/4 with an additional leaf for tool boxes, it's all
relative, you can never have too much truck, just keep the
coffee cup 1/2 full.
Old Jan 23, 2004 | 12:31 AM
gilraine's Avatar
gilraine
I didn't think that it was too bad.. I think that my dad's dakota(01)rides worse than my old f-250 ever did...good shocks are a must...
Old Jan 24, 2004 | 09:58 AM
bcf's Avatar
bcf
My truck had a great ride when I got it, possibly the original shocks. Almost as smooth as my old Legacy. But when I put the timbrens on that dissapeared.
Old Jan 24, 2004 | 01:00 PM
vman's Avatar
vman
Wear a kidney belt or put a thousand pounds in the bed.
Old Jan 24, 2004 | 10:20 PM
BobBarry's Avatar
BobBarry
I have to say that my '97 F-250HD's ride is REAL smooth. I don't know if it's the original shocks or what, but it's by far smoother than my '88 Jeep Grand Wagoneer. Of course, the F-250's a 2wd and a Supercab longbed, so it has front coils and a 155" wheelbase, which probably make a difference.
The only time it's even somewhat rough is at slow speeds over rough roads. I find that if I drive over the same section at higher speeds, the suspension just soaks them up. The highway ride is just outstanding, though; it was the first thing I noticed when driving it.
