Software
Old May 25, 2018 | 12:48 AM
jhinalabama's Avatar
jhinalabama
Software
What diagnostic software do you like to use with a laptop. For the DIY guy's. I would like to reset my transmission memory so it could learn my driving habit's.
Old May 25, 2018 | 08:12 AM
Olytlr's Avatar
Olytlr
You just need to do a KAM reset. This can be done by disconnecting the positive and the negative on the battery and touching them together or if you have a tuner it's just the press of a button.
Old May 25, 2018 | 08:15 AM
Olytlr's Avatar
Olytlr
Old May 25, 2018 | 11:37 AM
rbentnail's Avatar
rbentnail
jh in AL -> Contrary to internet lore, it's not necessary to do this more than once. Unless of course you want to reset the tranny settings more than once
Olytlr -> just givin' you crap. My neenerwebs is all F'd up today too, had to vent on somebody
Old May 25, 2018 | 01:12 PM
jhinalabama
I just bought the truck about 3 weeks ago with 171k of someone else's miles on it. So I thought it would be nice to reset the memory. As far as the diagnostic software what do you guys have good luck with or like using forscan ids ect.
Old May 25, 2018 | 07:09 PM
projectSHO89's Avatar
projectSHO89
The transmission has no memory, therefore, there is no reason to make it forget what it doesn't have.
Old May 25, 2018 | 07:37 PM
Robbgt's Avatar
Robbgt
Maybe no memory, however it does adapt to the driver over time. From the manual:
"Automatic Transmission Adaptive Learning This feature is designed to increase durability and provide consistent shift feel over the life of the vehicle. A new vehicle or transmission may have firm shifts, soft shifts or both. This operation is considered normal and will not affect function or durability of the transmission. Over time, the adaptive learning process will fully update transmission operation. Additionally, whenever the battery is disconnected or a new battery installed, the strategy must be relearned."
Old May 25, 2018 | 08:10 PM
jhinalabama
Sorry I didn't use the proper nomenclature. Adaptive Learning. I call Helicopters airplanes to.
Old May 25, 2018 | 08:46 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The software does NOT adapt to the driver. It doesn't say that it adapts to the driver in the wording you quoted. Take it from someone that programmed that software, it adapts to the individual transmission. It also adapts over the life of the transmission to account for wear.
The purpose of the adaptive software is to maintain the ideal slip time during a shift over the life of the transmission. A nominal setting is programmed into the software. Some transmissions will have ideal slip times with that value, some will have long slip times, and some will have short slip times. The adaptive software changes the pressure commanded for the shift so that every shift has the ideal slip time.
And yes, there is memory to store these values. There isn't a need to clear it, the software is always measuring the shifts and making changes where it's needed. Different drivers do not upset it, nor does the software need to learn or unlearn different drivers. It just learns slip times.
Old May 25, 2018 | 10:00 PM
jhinalabama
Thanks for your input. Along with optimizing transmission performance I thought that it learned some driver habits also. Thanks for clearing that up.
Old May 26, 2018 | 09:25 AM
rsylvstr's Avatar
rsylvstr
awesome info as always. Thanks.
Old May 26, 2018 | 01:45 PM
Robbgt's Avatar
Robbgt
Sorry for my misinterpretation or the manual language. I was under the impression that something learned as the trucks I've driven with the same motor do not shift the same.
Thanks for clearing that up Mark
Old May 30, 2018 | 03:08 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
To address your other question, Forscan is the way to go. Get yourself a Bluetooth OBD adapter like this one and you're all set. That's the one I use.
Old May 30, 2018 | 11:56 AM
jhinalabama
Thumbs up
Thanks for addressing that. I did download forscan on my laptop, I seems to work well. I don't have the phone app yet, but I do have a bluetooth OBD adapter. I just need to check compatibility. Thanks for the input.
Old May 30, 2018 | 02:44 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
The phone app is much less powerful than the laptop. It's basically just a gauge app for your phone. All of the programing needs to be done on your laptop.
I'm buying a lot of Toughbooks from my work here in the next month or so. I'm thinking I'll keep one under my seat for truck stuff.
Norma stitz
Oct 8, 2016 09:16 AM
mustangski
2004 - 2008 F150
Feb 24, 2009 03:15 AM
drj777
Computer Chips & Tuners
Mar 22, 2007 05:54 PM
mill666er
Sep 13, 2005 05:15 PM
Sidewaze
Nov 20, 2004 11:53 AM
