2006 horrible vibration
Old May 23, 2018 | 09:04 PM
dlynes's Avatar
dlynes
Horrible vibration and shake/wobble. Vibration started about 20 miles ago while driving on the highway around 70-80 mph. Initially it only shook going above 30 but on a test drive today, it shook going around 5mph. About 150 miles ago, I noticed a noise while in 4x4 and I ignored it. Then, I started hearing a howling noise while driving in 2wd. Model type and recent services below. Any recommendations on what to check? Another person recommeded for me to Check the u joints, if you have a 2 piece rear driveshaft check the center support bearings and with a lowered truck and if not the bearing is not lowered, you could be inducing your own new problem. Thanks so much!
  • 2006 F350
    • Lifted and on 35 tires
    • SRW
    • 4x4
    • Auto
    • Long bed
    • Crew cab
    • 212k miles
  • Recent Service (less than 1,000 miles ago) / Ford oils and filters with exception to Shell engine oil
    • Drained and refilled front differential
    • Replaced front hubs
    • Rear Hubs
      • New bearings, seals, and races
    • Brakes
      • Installed all new calipers and new pads
      • Surfaced rotors
    • Transmission - drained, refilled and placed both filters
    • Engine oil - drained, refilled and replaced filter
    • Engine Coolant - Flushed and refilled 5 times til clean
Old May 24, 2018 | 08:54 AM
navistarnut's Avatar
navistarnut
Wheel hubs perhaps
Jack up the front and take the tire, either side, and try to rock it top to bottom and side to side.
Old May 24, 2018 | 04:18 PM
dlynes's Avatar
dlynes
Originally Posted by navistarnut
Wheel hubs perhaps
Thanks but I just replaced and serviced all four hubs.
Old May 24, 2018 | 04:27 PM
seville009's Avatar
seville009
should still check; might have installed a defective part, or something happened since it was installed.
Also just crawl under the truck and look/feel around for loose parts.
Old May 24, 2018 | 08:27 PM
navistarnut
What brand of front hub did you purchase?
Old May 26, 2018 | 08:59 AM
dlynes's Avatar
dlynes
Timken. My driver side front hub failed before and the truck wobbled but this time, it is significantly different and worse. it's undriveable now due to this. before, I could drive on a bad hub and it just made it annoying.
Ill inspect the driveshaft u-joints. I briefly tested one for play while in neutral and there was some play. I have zero experience with u-joints and driveshafts. should there be any play at all?
thanks for your help!
Old May 26, 2018 | 09:34 AM
FiznUKa's Avatar
FiznUKa
How tall of lift did you install? Did you shim the carrier bearing? The only way to really check the u-joints on the drive shaft is to remove it completely. And no there shouldn’t be any play in the joints.
Old May 26, 2018 | 02:43 PM
dlynes's Avatar
dlynes
I have no idea. bought it as is and its been lifted since at least around 90k miles.
Old May 28, 2018 | 02:30 PM
dlynes's Avatar
dlynes
  • 2006 F350
    • SRW
    • 4x4
    • Auto
    • Long bed
    • Crew cab
    • 212k miles
    • Rear Hubs
    • Brakes
      • Surfaced rotors
Mechanic is looking at it and after test driving it, he believes something inside the front differential is messed up
How big of repair could that be?
jimlj
May 26, 2017 01:42 PM
usmcBTC
Mar 10, 2010 06:09 PM
jdap
Feb 20, 2008 11:54 AM
DetailerDave
Jan 30, 2008 11:04 AM
Hiram
Dec 2, 2004 06:45 AM
