i have a 2005 F150 with the 5.4L.. the previous owner removed the cats and straight piped it when the cat clogged. so now i just have my upstream 02 sensors. so of course i have check engine light for 02 sensor heater circuit sensor 2.. my question is i also have bank 1 lean and bank 2 lean.would not having the downstream sensors cause the computer to think its running lean? im getting 11mpg in town or so. It doesnt feel like loss of power and runs fairly well. just curious if not having downstreams trick the computer to think its running lean when its not?
No. The downstream O2s are only used to monitor CAT efficiency.
The upstream O2s are used for fuel control and if the PCM adds max fuel to try and get the mixture back to stoic, it sets the lean code(s).
What is the exact code number you are seeing? Given your fuel milage I wonder if the code is actually (at lean adaptive limit) which means the computer knows the engine is running rich but has reached it's adjustment limit in it's efforts to lean it out. If that is the case you may have a problem with the fuel delivery system, fuel pressure too high or maybe one or more injectors are dirty and leaking extra fuel into the motor. Either way it's not likely you have a primary O2 sensor problem.
FYI, there are O2 eliminators available for the downstream sensors that will "fix" you check engine light problem.
Say whut? P0171 and P0174 means fuel trims have reached 'maximum' positive adjustment limit on lengthening injector pulse widths - and thus its efforts to "RICHEN" it up. (depending on whether we are applying the rich / lean terms to fuel ------ or oxygen). But the DTCs are referring to FUEL. @projectSHO89 is correct.
"O2 eliminators" will not fix either of your truck's problems, so forget about them.
I find that statement a bit surprising so I had a look on the web for these and all I see are things that look like 1" sensor spacers, harness extensions of some type and other crap, it seems this market has been totally saturated with gimics of late. I had to dig to find the device I was referring to which is something that plugs into the chassis wiring harness only to simulate the output of an O2 and the sensor itself is totally removed. I don't know where one would buy these but when you do it will look like this. These will address your missing downstream sensor codes only, they won't do anything for the lean codes which I agree are most likely the result of a vacuum or exhaust system leak.
You will kindly notice my original response was before the actual code numbers were known so it was a shot in the dark.
The specific device you linked to is marketed to a very narrow year range of BMWs of one specific model line. These are not bimmers being discussed in this particular forum.
In order for such a device to emulate completely missing downstream O2 sensors on this era of Fords, it would have to do two (at a minimum) specific things:
1. Successfully emulate the heater circuit. This could be done with a suitable high wattage, low value resistor.
2. Pass the PCM's test of the sensor's switching capability prior to running the catalyst efficiency test. This would fail since the simulator has no way of knowing when that test is executing.
Knowing how something is supposed to work is key to understanding whether or not an add-on is likely to work.
Originally Posted by awon
i have a 2005 F150 with the 5.4L.. the previous owner removed the cats and straight piped it when the cat clogged. so now i just have my upstream 02 sensors. so of course i have check engine light for 02 sensor heater circuit sensor 2.. my question isi also have bank 1 lean and bank 2 lean.would not having the downstream sensors cause the computer to think its running lean? im getting 11mpg in town or so. It doesnt feel like loss of power and runs fairly well. just curious if not having downstreams trick the computer to think its running lean when its not?
