Sponsored by: Auxito
P0174 and P0175
Old Jan 3, 2007 | 05:43 PM
blade14264's Avatar
blade14264
Cool P0174 and P0175
My F150 is getting the following codes.
P0174 System Too Lean - Bank No. 2.
P0175 System Too Rich - Bank No. 2.
An i am at a loss as to how the same bank can be both Too Rich and Too Lean. Truck runs fine in cool weather but like absolute crap when it is warm out.
Any suggestion as to what might be causing it to run BOTH lean and rich on the same side?
Old Jan 3, 2007 | 08:30 PM
Ultramagdan's Avatar
Ultramagdan
I would clean your MAF sensor and check for a vacuum leak from the PVC elbow. Reset the computer. Which code pops up now?
Old Jan 3, 2007 | 08:38 PM
Wilber15's Avatar
Wilber15
Just a thought. Can you watch your PIDs? Check the ECT sensor for a very low negative reading. A faulty ECT sensor could set your fuel trims very rich(thus setting a rich code?) and the O2 sensor could have then gone bad from the extra fuel setting a lean code at a constant low value? I have no idea where to start either, but this could be a hint? try watching the O2 sensor PIDs and see how they respond under different conditions.....
Old Jan 3, 2007 | 10:07 PM
Ben-jamin's Avatar
Ben-jamin
chech the connections at the o-2 on that side, make sure they're clean and secure. Also it may be contaminated-any sign of oil consumption? do you have a scantool with datasteam capabilities? if so watch how fast it becomes active-compare it to bank one
dreyko
Oct 6, 2021 11:13 AM
WhyFord
163
Feb 17, 2017 07:49 PM
ufvj217
2009 - 2014 F150
Sep 29, 2015 08:06 PM
msradio
Jan 22, 2013 08:16 AM
MrBookworm
Jan 28, 2006 09:47 PM
