I've had BAK trifolds on the last 3 trucks. I went with the ProZ from autoanything on my 2018. I'm glad I did. I saved $300 and I actually like the design better. You can close the tailgate with the cover down and it has a better system for locking the tonneau in the up position. It also seems to keep the water out around the tailgate a little better. I also had issues with the finish on two of my BAKs. So far the ProZ is holding up well.
Agree with Baks of more than 2 years ago. But you can close the tailgate with the cover down. Added extra gasket around tailgate. And there is a night/day difference between the M1 and F1 tops regarding dings and weather issues. Linex also has similar tops as well. I wouldn’t use the aluminum top in Florida because of our numerous hailstorms. Just thought people here need to realize there have been improvements to past problems.
Ordered 2x from linex today. Manufacturer part number for 2017+ short bed linex LXP, same as bak-f1, is TG95330. I was able to use this PN to make exactly sure the two dealers I spoke to were referencing the same part.
will follow up on install after I get the truck.
I bought my last tonneau from Linex around June10.
Interesting that I have the same part #TG95330 but mine is labeled Line-X FRP not LXP. So yours might be a slight upgrade in just the last 2 months.
Does the Bakflip or Linex version of it, come with the option of the linex coating on top? Seems like I saw somewhere that you could get it with it already linex'd which helped in dings and scratches. Not sure how it would be for keeping it clean though.
Originally Posted by Larrymac52
On the Backflip F1 or the Linex version Truck Gear hard cover I doubt you could make a dent in it with a hammer. This is a composite fiberglass not the aluminum like the Bak M1 which will get dents from hail. The Linex people can pretty much coat anything but IMO you’d just be putting unnecessary weight on your top while spending unnecessary money. Again that’s just my opinion— maybe someone else who has an F1 can chime in.
