Hi, All
I am upgrading my '67 F250 Camper special with 1979 F250 front disc brakes w/ the '79 booster. The spindles look a bit rough, and one of the radius arms has major wear due to a worn out bushing.
Can anyone supply me with part numbers for the 73-79 spindles, dust shields, and radius arms to assist my search for parts. Also just what front suspension parts on the '67 are compatible, can I reuse the radius arm(s) for this conversion? also, if anyone has installed a later model brake booster, did you have any difficulties doing so that you'd care to share?
Thanks in advance, folks FTE has so far been an invaluable resource for me, and I'm glad to be a member of this community!
I'm learning that the radius arms aren't readily available in an aftermarket fashion. I've had to look in junkyards and online for radius arms for my 1978 F250 2WD. I'm not sure what's compatible across generations, but I'm sure other folk can weigh in. Are you running 4WD or 2WD?
Also just what front suspension parts on the '67 are compatible? none.
If anyone has installed a later model brake booster, did you have any difficulties doing so that you'd care to share?
1979 F250 2WD: Regular, Super or Crew Cab; single or dual piston calipers; what is the GVWR?
Hi, and thanks for the responses. The donor truck is a 6200 gvw, regular cab, with single piston caliper. I would like to use the dual piston setup, but haven't come across any parts for that. I have not found any junk yards that fess up to having any trucks of the 60's - 70's generations.
1975/79 F100/150 2WD; 1975/79 F250 2WD Regular/Crew Cab; 1975/79 F250 2WD Super Cab except with 8,100 lbs. GVWR
----- D5TZ-3105-F Right & D5TZ-3106-F Left .. Front Spindle-Use with single piston calipers / Obsolete
1975/79 F100/150 2WD; 1975 F250 2WD Regular Cab with 6,200/6,900 lbs. GVWR from serial number W40,001; Ditto 1976/79 F250 2WD Regular Cab.
----- D4TZ-2K004-B Right & D4TZ-2K005-B Left .. Dust Shield-Use with single piston calipers / Obsolete
1974 F100/250 2WD from serial number U60,001; 1975/79 F100/250 2WD
