Radius Arms
Old May 16, 2017 | 10:49 AM
TTurnquist's Avatar
TTurnquist
Radius Arms
Do these radius arms look usable or should I start looking for some better ones? 1978 F100 300 six 2wd 3 speed
Thanks
Old May 16, 2017 | 11:09 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D5TZ-3A360-A .. Radius Rod - R/L same / Obsolete
1975/79 F100/150 2WD; 1975/79 F250 Regular & Crew Cab; 1975/79 F250 Super Cab under 8,100 lbs. GVWR
No Ford dealer or obsolete parts vendor has any.
Old May 16, 2017 | 01:49 PM
ultraranger's Avatar
ultraranger
If in doubt, change them out. Best case scenario is to find good replacements from a donor truck. Worst case, take the existing arms to a machine shop, have the welds ground off, remove the worn pins, have new pins machined with a 3/4"-10 thread on the ends, weld the pins into the arms and reinstall the arms on the truck.
Old May 16, 2017 | 02:05 PM
TTurnquist's Avatar
TTurnquist
That may be the most expedient way to do it. Most of the local stuff around here wouldn't be in much better shape.
Old May 16, 2017 | 08:32 PM
good to doo's Avatar
good to doo
Good call, that's what I was going to say.
Old May 25, 2017 | 09:30 AM
TTurnquist's Avatar
TTurnquist
Name:  Radius Arms Fixed.jpg
Got a local machine shop to make new shafts.
Old May 25, 2017 | 10:06 AM
HIO Silver's Avatar
HIO Silver
Nice.
I suggest applying POR-15 to stave off corrosion. And then apply sealant where the old and new interface.
Old May 25, 2017 | 01:37 PM
TTurnquist's Avatar
TTurnquist
Good idea, will do. Thanks
TeachNlive4ever
Jun 4, 2018 02:01 PM
Gavin Kerr O'Dell
Dec 30, 2017 12:28 PM
dclary
Feb 4, 2009 04:28 AM
GPZF100
Feb 6, 2008 11:40 PM
79F150FT
13
Jul 10, 2005 09:29 PM
