I spent a good deal of time searching for this subject before posting, and if it's a repeat question, I sincerely apologize.
I own a 1977 F100 2wd Flareside with a 351M. In preparation of radius arm bushing replacement, I noticed that my right side radius arm has a slight upward bend. I used to do alignment work, and know that back in the day it was not uncommon to bend the radius arm slightly to correctly set caster angle (although I personally never did it, my boss would occasionally do so for customers).
Short story long. If in fact, this is not a intended bend and I must replace it, I am curious if the radius arms from a 2wd F250 will interchange?
My suspicion is that it won't as I have learned (from this forum) that F100 and F150 will interchange, but no mention of F250.
Any ideas? Any help will be very much appreciated.
Thank you for the reply. I was looking at them at the junkyard today, and visually there seems to be no difference, but I wasn't sure. Only 73-79 trucks in the local u pull it are F250 2wd. I would rather buy from them if possible.
