Keyless entry programming
Old May 19, 2018 | 10:30 AM
Jason Lilly's Avatar
Jason Lilly
My new to me 99 E350 15 passenger van with power door locks didn't come with a key fob so I purchased one online .
Im trying to find the 2 prong wire under the driver side dash so I can bridge the wires and set it up for programming but for the life of me I cannot find the wires.
Ive read and read thru multiple posts on this and other forums but just cant locate the wire.
Does anybody have an actual photo of the wire and where its located ?
Thanx
Old May 19, 2018 | 12:51 PM
wiskeyVI's Avatar
wiskeyVI
On my van, it is just a matter of cycling the ignition so many times and then hit one of the remote buttons.
Old May 19, 2018 | 07:25 PM
Jason Lilly
Yeah I tried that route as well .
The remote seller specified I needed to find that wire and bridge it to set it in scan mode.
Old May 20, 2018 | 07:16 AM
Im50fast's Avatar
Im50fast
thats odd. I’ve never heard of that. Can you post a pic of the instructions?
I feel pretty strongly that the other guy was right. Do you have an owners manual?
Every Ford I’ve owned allows the owner to program a remote as described above.
Old May 20, 2018 | 09:48 AM
pancake52's Avatar
pancake52
yes you need to bridge that connector 98 conv. van
its underneath the steering column .next to impossible to see or find. I'll see how mine is marked and post that asap. I've got a 1998 e150
van and it was impossible to program, without jumping the pins.
Old May 20, 2018 | 01:39 PM
pancake52's Avatar
pancake52
Talking Black plug with 2 wires 1998 E150 conversion van
on my 1998 e150, my notes show its a black plug with 2 wires. one wire is white with yellow stripe and 2nd wire is black . its a plug underneath the steering column.
1. I jumped the plug internal pins with a very small piece of wire. ( I think it locks then unlocks)
2. Then turn on ignition key to run
3. Press any keyfob button to program
4.Then ignition key to OFF
5 Remove Pin Jumper(WIRE) from black plug connector
kengarchow
Dec 10, 2018 04:55 AM
2004CSOTP
Apr 24, 2018 05:40 PM
Nev. Bronco
1978 - 1996 Big Bronco
Apr 21, 2009 08:23 PM
ryan.siebert
Jun 13, 2007 12:16 AM
SonicBlueF350
Jul 18, 2003 03:16 PM
