C6 transmission fluid
Old May 15, 2018 | 08:34 PM
Gigemags05's Avatar
Gigemags05
I’ve got an 82 c6. The dip stick says to use M2C138-CJ, which I have read is dexron III/mercon.
I have also read that people still use type f fluid in transmissions that call for M2C138-CJ because it creates firmer shifts. Is this true? If so, are there any downsides to using f? I assume so if the transmission was made for M2C138-CJ. But I would like to have a little firmer shift, especially if it can help prolong the life of the trans.
Is there much quality difference in brands?
Old May 15, 2018 | 08:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
TYPE F ATF = 1964/76 C4 & 1966/76 C6 // MERCON = 1977 and later C4 & C6.
Old May 16, 2018 | 08:24 AM
Franklin2's Avatar
Franklin2
I would use the dexron/mercon stuff. If you want to spring for the cost, you could actually use the dexron VI, it is a semi-synthetic and is backward compatible and recommended for all the old dexron uses. Walmart is the cheapest place to get it.
If you want firmer shifts, I would put a mild shift kit in it.
1981 F100
17
Jan 6, 2019 07:11 AM
jim6346
Dec 10, 2014 05:28 PM
smoke n tires
Oct 13, 2004 07:31 PM
bigblocksix
May 24, 2004 08:12 AM
joe btrucks
Jul 19, 2002 12:41 PM
