C6 Transmission Fluid
Old Dec 10, 2014 | 01:14 PM
jim6346's Avatar
jim6346
Hello Everyone,
I put a 429 into a 65 F100 with a C6 transmission with a mild shift Kit. Both transmission and torque converter are bone dry. How much total fluid does it require? NAPA says I can use Mercon V, but the dipstick says Type - F. Are these interchangeable?
Thanks,
Jim
Old Dec 10, 2014 | 01:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C6: 1966/75 TYPE F / 1976/96 Mercon // C6 takes approximately 13 quarts.
Old Dec 10, 2014 | 02:46 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
They are NOT interchangeable. If your trans has the original parts MERCON V will kill it. If it has been rebuilt with newer plates that are compatible with MERCON or MERCON V, then it will shift very harshly with Type F.
Old Dec 10, 2014 | 03:11 PM
jim6346's Avatar
jim6346
Well shoot!! The guy does not know what year it was or what they used for parts when he had it rebuilt. Don't suppose there is one in the middle
Old Dec 10, 2014 | 04:36 PM
ras4434's Avatar
ras4434
What about Amsoil?
Old Dec 10, 2014 | 04:48 PM
jowilker's Avatar
jowilker
Go with the dipstick use Type F.
John
Old Dec 10, 2014 | 05:28 PM
TBird Larry's Avatar
TBird Larry
Originally Posted by ras4434
What about Amsoil?
Defiantly go with synthetic AMSOIL, it won't harm your trans and it will last much longer and run cooler. You don't have to worry about type F or mercon it will just work. It cost a little more but well worth it.
Check it here: AMSOIL Synthetic Automatic and Manual Transmission Fluid
Good luck....
1981 F100
17
Jan 6, 2019 07:11 AM
Gigemags05
May 16, 2018 08:24 AM
sigtauenus
Apr 26, 2007 05:59 PM
smoke n tires
Oct 13, 2004 07:31 PM
bigblocksix
May 24, 2004 08:12 AM
