ATF FOR A C6?
Old Jul 18, 2002 | 04:27 PM
joe btrucks's Avatar
joe btrucks
ATF FOR A C6?
Hi, for a ´81 C6 on a Bronco,what ATF requires Dexron II D or
Dexron III?what is the difference?
Thanks
Old Jul 18, 2002 | 09:27 PM
Brian460's Avatar
Brian460
ATF FOR A C6?
I am pretty sure that you would want to use type F, although I have heard of using Dextron III, they don't shift as firmly.
Brian
Old Jul 19, 2002 | 08:15 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
ATF FOR A C6?
I have a copy of Ford TSB 01-15-7, which specifies ATF for all Ford transmissions.
For a 1981 C6 it specifies MERCON fluid.
Mark
Old Jul 19, 2002 | 09:56 AM
Boss_358's Avatar
Boss_358
ATF FOR A C6?
DO NOT put type F in a 1981 C6. Ford started making the C6's to run Mercon and Dexron II in 1977. Dexron III is the higher and newer equivelant to these fluids so running that is fine. I do not no really what the difference is between the fluids but I know that you can run either one. Plus usually when you buy a bottle of fluid it says Dexron/Mercon on it. Type F was used in C6's through 76 and in C3's and C4's through 79. After that I think Ford started getting away from using asbestos friction disc's and clutches and therefore needed to change fluid type as well.
Old Jul 19, 2002 | 12:41 PM
F_150_hotrod's Avatar
F_150_hotrod
ATF FOR A C6?
vesuvius5402
Dec 2, 2012 04:46 PM
Bertha1
24
Jan 6, 2007 08:55 PM
Lead_Foot
Aug 3, 2005 07:27 PM
fordiesel69
Dec 1, 2000 08:18 PM
fordiesel69
Nov 30, 2000 08:59 AM
