c6 fluid
Old May 22, 2004 | 12:10 AM
bigblocksix's Avatar
bigblocksix
c6 fluid
what kind of fluid would an 86 c6 take?
Old May 22, 2004 | 12:54 AM
calazo's Avatar
calazo
Arrow A/T Fluid
Get any fluid that holds the MERCON (Ford's) standard or even GM's DEXRON. My C-6 works fine with Exxon/Mobil ATF. Those A/T sealers & conditioners help too, just check for leaks and the right fluid level regularly.
Old May 22, 2004 | 02:53 AM
TNTsF-250's Avatar
TNTsF-250
calazo, is right, any MERCON/DEX II,trans oil well do ,i have a 75 F-250 ,i just put in a new TCI Trans out of summit raceing a C-6 i"m useing DEX III + .
Old May 22, 2004 | 07:27 PM
rclarke's Avatar
rclarke
Ford used Type F until May 1976 then changed to type CJ which turned out to be an orange colored Dexron II which was changed to Mercon/Dexron III. So, as recommended above all C6 transmissions built after May 1976 use Mercon/Dexron III.
Old May 24, 2004 | 08:12 AM
msmarcus's Avatar
msmarcus
I was told by the guy that rebuilt my C-6 that all rebuild kits now are set up to use Mercon. So if it has been rebuilt recently, it would be that fluid.
kcode
Dec 30, 2011 08:19 PM
tuekwik
Jan 24, 2006 05:20 PM
dj8667
Jun 20, 2004 01:14 AM
otto
Nov 29, 2001 06:28 AM
karljay
Mar 20, 2001 10:51 AM
