c6 fluid -help-
Old Oct 12, 2004 | 07:22 AM
smoke n tires's Avatar
smoke n tires
c6 fluid -help-
someone please tell me what trans fluid to use in my 78 c6. ive heard mercon 2. i like type f cuz it shifts better. will it hurt it? will mercon 3 work? i dont see mercon 2 anywhere at the stores but mercon 3 is cheap. please answer only if your sure, i dont want to hurt my daily driver. thank you...
Old Oct 13, 2004 | 06:36 AM
rclarke's Avatar
rclarke
Mercon III is the proper fluid for all C6 transmissions built after May 1976.
Old Oct 13, 2004 | 10:13 AM
smoke n tires
thank you, this is good cuz that type is cheap.
Old Oct 13, 2004 | 07:31 PM
mhg's Avatar
mhg
check your dipstick
usually printed on the stick
my c6 that came out of a 83 e150
says dextron
when I put it in my 76 e150 I did a complete drain and refill with a shift
kit
refilled with type F and it works great
