EBEARS BUILD
Old Jan 12, 2021 | 09:50 PM
  #61
EBEAR's Avatar
EBEAR
From that angle it sure looks like allot . There are no pics in your hood thread do you have any side shots ?
Old Jan 13, 2021 | 05:45 AM
  #62
thepitshop's Avatar
thepitshop
such a long time ago,I'd have to check my old computer ,I'm sure i have them on there, these days everything is on the phone!
Old Jan 13, 2021 | 05:46 AM
  #63
thepitshop's Avatar
thepitshop
Originally Posted by Fomoko1
Thanks Gil. What are your plans for it?
not sure, some days I want it gone,others I'd like to keep it as a retirement project, if that ever happens!
Old Jan 13, 2021 | 07:29 PM
  #64
EBEAR's Avatar
EBEAR
A little more progress with allot of time . I would also appreciate any input on errors or things that could be done differently as this is my first shot at this type of mod .
I did a great job of making sure I had very little outside body work but not so much on the inside
now that the easy part of the chop is done we start making all the little pieces to make everything look right . 1 of 5 pieces needed to make it right on 1 side
not going to get into all of the pieces but obviously the door needs to follow a a curve
some where close
oversight committee
Old Jan 13, 2021 | 08:23 PM
  #65
Marten's Avatar
Marten
Are you going to put more weld on the joints? On the second last pic I see tacks but then a small gap then more tack then a gap. would be good to fill the joint right across with tacks. Take your time, let it cool then more welding. Hammer and dolly the tacks as well. On the inside afterwards I would smear some seam sealer over the joint to seal it, where ever you will not see the sealer.
Perhaps you know that already though.
Old Jan 13, 2021 | 08:30 PM
  #66
Drewski 2's Avatar
Drewski 2
Hang on to it Gil. I've been on and off my truck since 1986. Many projects have come and gone. I've had lots of chances to sell it, but I had done so many radical changes, I felt like I would eventually see it through. Since I got it running I've had a blast with it, and it is still not finished. Too much time invested to call it quits.
Old Jan 13, 2021 | 08:45 PM
  #67
EBEAR's Avatar
EBEAR
Yes I should have said it's not finished . But thanks , it never hurts to mention things you see , sometimes even when we know better the excitement of making progress makes us overlook things . There is a ton of welding and grinding left to do on the things I have just done . But as I have a small shop and I still need to work for a living my aim right now is to get this particular part built and tacked so it can be moved out of the way .
Old Jan 14, 2021 | 06:03 AM
  #68
Damian Kade's Avatar
Damian Kade
EBEAR, That is coming along nicely!!! I am glad you decided to curve the top door corner, looks great. I still need to finish the doors and inside to my chop project at some point, you are giving me hope. Keep up the good work!!!! Can't wait to see some more progress.
Old Jan 17, 2021 | 10:25 PM
  #69
EBEAR's Avatar
EBEAR
So a little update before it gets pushed to the side for awhile .
after looking at the pics I realized that the door frame got wider at the bend which seemed to bother me
so I used my calipers to scribe it closer to equal
much better
can't be too far out as my pattern for the drivers side filler fits the passenger side
one pass of metal reinforced filler
needed to fill the gap after trimming the door more . It's twice as good if you do it twice right ?
Old Jan 18, 2021 | 07:15 PM
  #70
Marten's Avatar
Marten
Looking good. Was thinking of doing that door change on mine as well. Lets see a pic once you have the welding done.
Old Jan 19, 2021 | 06:06 AM
  #71
thepitshop's Avatar
thepitshop
much better
makes a huge difference! like the rounded look!
grinnergetter
41
Apr 8, 2025 10:24 AM
petemcl
Feb 22, 2016 09:43 PM
snook715
413
Nov 2, 2015 05:36 PM
Scotty's 52 F3
Oct 29, 2015 08:37 PM
FoMoCoPower
31
Sep 21, 2014 05:11 PM
