Electrical wizards? Dash resistor question
Old May 14, 2018 | 03:45 PM
GoldCo's Avatar
GoldCo
I’m using harness(es) from ‘95 for my ‘52 F3.
Stripped away stuff I don’t need, but will be using aftermarket gauges. Wondering what function the resistor has for the “charge” indicator? Is it important for proper function or just built-in to the instrument circuit board? In other words I was planning to just use a small 12v bulb for this purpose, having found the correct wires feeding the instrument panel.
Or, must I clip this resistor out and solder in my bulb circuit?
See photo for reference. Thanks. ​​​​​​​
Old May 14, 2018 | 04:41 PM
rla2005's Avatar
rla2005
The resistor is there to provide a current path for when the bulb may be burned out.It's a simple shunt resistor around the bulb. If the resistor was not there, or open itself, there is no path for the exciter voltage to turn on the alternator in the event the bulb is open.
Old May 14, 2018 | 04:45 PM
GoldCo's Avatar
GoldCo
thanks... i wondered about that (if it had something to do with bulb burn out workaround). good to know!
assume the same is true then for the CEL and brake indicator?
so should i try to clip and solder, or not worry about it too much knowing that the (new) bulbs will likely outlast the truck?
Old May 14, 2018 | 04:48 PM
GoldCo's Avatar
GoldCo
P.S.
what exactly triggers the brake light btw?
is it just in case emergency brake is left on?
Old May 14, 2018 | 06:16 PM
GoldCo's Avatar
GoldCo
Actually just realized these are 12v LED indicators, so shouldn’t have “burn out” issues. So can I skip the inline resistors?
Old May 14, 2018 | 06:27 PM
TooManyMIce's Avatar
TooManyMIce
LEDs pass very little current compared to the incandescent bulb you're replacing. I'd keep the resistor.
Old May 14, 2018 | 09:30 PM
White 97 xlt's Avatar
White 97 xlt
X2 The LED will not put enough resistance/load on the circuit, so it will not charge without the resistor... Like he said "keep it"
Old May 15, 2018 | 07:21 AM
rla2005's Avatar
rla2005
No
As stated by the other responses I would keep the resistor in the circuit.
Old May 15, 2018 | 07:25 AM
rla2005's Avatar
rla2005
P.S.
Parking brake position switch, low brake fluid level, bulb prove out when cycling the key from Off to Run. On a diesel I believe there is a low vacuum switch that will trigger a yellow brake light as well.
Old May 16, 2018 | 11:33 AM
GoldCo's Avatar
GoldCo
So the 'charge' light is not just an indicator that something is wrong (as triggered elsewhere in the system), but rather is part of the triggering system itself?
But the CEL and brake lights are just indicators and would not need the resistors (other than in the case of a burnt out bulb)?
As for the brake light, if the above statement is true, can I get by without it (or does the ECM need to see the circuit in that bulb prove out you mention)? As stated, this is all for a '52, with either aftermarket or junkyard parts, so I won't have a parking brake position switch or any kind of fluid level sensor.
Thanks for the insight.
Old May 16, 2018 | 01:25 PM
rla2005's Avatar
rla2005
You are correct
You are correct
The ECM (computer) is not concerned about that circuit. The prove out function is only momentary for the operator to view the indicator bulbs. So if there is no bulb in place, no errors or codes will be flagged.
edzakory
18
Aug 30, 2017 07:10 PM
rechinca
Sep 17, 2016 12:06 PM
jgwatson109
General Automotive Discussion
Mar 23, 2016 10:08 AM
Rusty_S
Mar 18, 2016 07:52 PM
sweetlou1
Mar 31, 2013 10:12 AM
