Towing with the 2018 F-250 diesel
I'm not use to such a big truck.
I usually tow my horse trailer (locally ) with my 2008 Tacoma.
I would drive in D no overdrive and shift when needed.
Now I have this 2018 F-250 Turbo Diesel monster
This is like a smart phone (too smart for me ) for me.
It has tow/haul mode ? What
Now I want to tow my Horse trailer with a weight dist. hitch and sway control
What do I do...
I'm looking for some general guide lines as to what setting etc.
Thanks
Sean
What do I do...
Thanks
Sean
Received 6,776 Likes
on
Does the horse trailer tow OK without sway or porpoising? If so I wouldn't bother with a WDH. The truck can easily handle the weight, so that shouldn't be a concern. Some trailers tow better than others. I can tow my 11k toy hauler with a regular ball mount but the porpoising is pretty bad. With the WDH that problem goes away and also handles the small amount of sway.
That’s a really light trailer for weight distribution hitch. Surely not needed, unless you are only getting it for sway control. The picture is a little obscured, but it looks like the trailer is riding a little nose high. That can cause the trailer to constantly wiggle back and forth going down the road. I recommend just bringing the trailer back to level and towing with a standard ball.
Tow haul mode changes shift points, TC lockup, etc. again, with that light of a trailer you can just drive like normal if you want. I’d turn on T/H mode when pulling the trailer, though. This engine and tranny are the same as my 450 that can pull over 30,000 lbs. a 6,000 lb trailer is hardly noticeable to the truck. Just go have fun.
Yep, just push the TH button and drive like normal. You can do this unloaded too. Try it around town you’ll feel the difference in shift points.
As far as the hitch, a good WDH is going to run you $300-500. It requires modification to the trailer as well. And, it triples the amount of time it takes to hook and unhook the trailer. The proper drop hitch will be $45-120 and will work with any other trailer you might tow. By all means, if you are set on WDH go for it, but the proper drop hitch will work just fine.
https://www.etrailer.com/Accessories...urt/17120.html
measure your current one and make sure this is a larger drop. There are several others on the site that have even larger drop. Also measure the bolt spacing on your current unit to make sure it is the same.
Since you already have the WDH gear, you can try with and without the bars and see what works best for you. Just be sure the trailer sits about level when hooked up.
I can't imagine needing a WDH on that trailer but that's just me. I'd get that trailer level and then see if it's better. I've towed a 2 horse slant with a tack room, so a little bigger that your's, thousands of miles to rodeo's and never had an issue. Yeah the horses move around a little. Maybe it's your shorter trailer that makes it uncomfortable? If our barrel horses got a little fresh I just brake check em.
I have basically the same truck and regularly tow a 24' enclosed trailer weighing nearly 9K lbs. No need for a WDH. Also, after trying both I really don't bother using the tow/haul mode. The truck is so comfortable pulling the trailer without it, turning it on isn't as comfortable. I do use the engine brake in the mountains. Try it without the WDH, you will probably do fine and won't have to mess with the extra effort to connect the WDH and set it up.
My truck and trailer. note there is no WDH. I have towed this trailer coast to coast and its been a rock the whole way.
This is a rental and since I already have the setup …. I do not want to buy another whole setup .. Just what I need to make it work for now.
This is why I have the WDH.
My normal ride / tow vehicle … Note the F-250 is so much taller ...
PS. Do you want to try to explain to my wife why … (not advised )
Last edited by Seanoo7; 05-09-2018 at 11:34 AM. Reason: Spelling and after thought
