Sponsored by: Real Truck
Steering stabilizer
Old May 6, 2018 | 07:44 PM
49 Ford F-1's Avatar
49 Ford F-1
Steering stabilizer
i was looking at upgrading my steering stabilizer on my E99 SD. I’m running 33in tires not lifted or anything. Would it be benifical to run dual or stay with single? The old stabilizer is a Rachero. I’m going through the front end replacing warn ould parts. Would there be a better brand like Fox I should go with?
Old May 7, 2018 | 12:47 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
There is very little benefit to a dual stabilizer for you. I did it for asthetics, but there isn't an appreciable performance difference, not at that tire size anyway.
Old May 7, 2018 | 05:35 AM
CollinsCD's Avatar
CollinsCD
I agree with Trey and staying with a single. I went with Bilstein stabilizer and very happy with the performance.
Old May 7, 2018 | 06:53 AM
Jo7.3's Avatar
Jo7.3
I too was looking for a stabilizer for my E99, and after researching and advice from people on here, I decided to go with a single stabilizer. My truck didn’t come with one, and I had a difficult time finding the bracket for mine. I ended up going with a moog stabilizer and bracket for $80 total. Only had it on one day, but so far there is a very noticeable improvement in how the truck drives and handles.
Heres the thread read that I started, lots of good info in here. https://www.ford-trucks.com/forums/1...-worth-it.html
Old May 7, 2018 | 08:15 AM
49 Ford F-1
I’ll stick with single SS. The question now is which brand? I was wanting to match my SS with new shocks and Struts. I have heard 5100, rs7000, and 9000xl for shocks and struts. Any thoughts? I’m wanting to try to get a little better ride, and ones that will last a long time. The struts that is on it now are carquest bruisers.
Old May 7, 2018 | 08:26 AM
maticuno's Avatar
maticuno
Spend the money on the Bilstein 5100's. Unless you're going to get into some really hardcore off-roading, there's no need to go with Fox/King/etc.
Old May 7, 2018 | 11:21 AM
Idaho_F250's Avatar
Idaho_F250
Jo, I'm sure I've seen the part number for the brackets before but I cant remember now, which bracket and stabilizer did you end up going with? My truck didn't come with one either, and figure it might help on the freeway with the roads we have here in Idaho.
Old May 7, 2018 | 12:34 PM
49 Ford F-1
The ones I was looking at was the Rancho rs7000mt, 5100, pro comp mx6, and the Fox performance 2.0.
Old May 7, 2018 | 12:42 PM
Sparky83's Avatar
Sparky83
i dont have over sized tires and my truck didnt have a factory equipped stabilizer on it... if your not equipped with one ford bends the mounting tab on the axle closed.. i went with the dual shock skyjacker kit for mine.. it was a night and day difference after i got it on... one thing id throw out there from my research prior to buying.. get the gas filled ones... the one complaint i saw over and over again with the hydraulic ones was put up more resistance and youll end up fighting the wheel more even in the single shock setups just to keep the wheel straight...
Old May 7, 2018 | 09:13 PM
Jo7.3's Avatar
Jo7.3
Here's the one I bought (wish I'd have looked at Jegs first as the price is much lower than what I paid from Moog's website) I too have a lot of really rough roads around me and the stabilizer did make quite an improvement.
Steering Damper Kit | Ford F-250 Super Duty 1999-2004
Old May 9, 2018 | 01:08 AM
brian42's Avatar
brian42
Veteran: Navy
I have Rancho RS9000XL shocks and have been very happy with them.
As for SS I've been through a few brands. IMO I don't think there's a huge difference between the well-known brands but usually get a Rancho or Pro Comp (whichever is on sale). They seem to last the longest on my truck (YMMV). Just make sure you get a SS and not a shock that fits. Shocks are designed for vertical use and SS are designed for horizontal use. Early on I let 4 Wheel Parts talk me into "saving some money" by getting a shock that fit the mounts for $15 less than a SS. That's the last time I did that.
As for lasting a long time that will depend on where you live and how you drive. The SS sits right out in front of the axle and has no shielding/protection from the elements. I also do a healthy amount of off-roading so it takes a beating on the trails and wears out faster than it will for others.
Old May 10, 2018 | 01:51 PM
4Wheelgreg's Avatar
4Wheelgreg
Bilstien steering stabilizer was 70 bucks on Flee-bay for the 5100 . I just bought a 2016 F-450 and the truck was having a hard time returning the wheel , had to crank the wheel back after turning . I took the stock Ford one off its hard as a rock like it was seizing up .
I put the new Bilstien on and was perfect , wheel came back just like it's suppose too . As far as requiring a dual stabilizer I would say no all that does is put a extra load on your steering box .
I have another truck with 42"s and it goes down the road nice and straight and just has a single .
Old May 12, 2018 | 01:20 PM
Long Haul's Avatar
Long Haul
I ran a Carli on my previous 2011, no complaints.
Mickey Bitsko
Jul 30, 2018 09:26 AM
*208*
Apr 17, 2015 10:07 AM
cliwel
Jun 13, 2011 10:21 PM
Muddy 13
Dec 7, 2010 03:34 PM
zstyle01
Apr 5, 2007 10:54 AM
