Staked u-joint question
Old May 6, 2018 | 04:33 PM
db_tanker's Avatar
db_tanker
okay folks starting to think after about 178k miles my u-joints might need replacement.
been doing research on these staked in u-joints and I have actually read where some folks just press them out with a large hydraulic press (which I have access to at work).
they press the cups past the stakes and then cut the rest of the u-joint out.
let me know your thoughts here folks please.
D
Old May 6, 2018 | 07:54 PM
tbear853's Avatar
tbear853
Saw a thread a couiple years ago referring to use of a cutter tool in drill to erase the stake, then cross was replaced as normally done using special size joint supplied in kit.
Others look for drive shafts with clips holding caps in, my '07 has such.
Old May 7, 2018 | 07:46 PM
db_tanker's Avatar
db_tanker
yeah called up 3 shops today...all of them told me they wouldn't do it.
so figure I'll be getting a new drive shaft.
Old May 9, 2018 | 09:49 AM
alloro's Avatar
alloro
In that case you have nothing to lose by trying.
Old May 9, 2018 | 06:38 PM
steve(ill)'s Avatar
steve(ill)
read the description of why to get a new shaft
https://www.ebay.com/itm/FORD-F150-2...gAAOxyhotSNd9j
Old May 10, 2018 | 11:18 AM
bigunit54's Avatar
bigunit54
I got my new driveshaft from Driveshaft specialist. They are out of Texas. Good people to deal with. Here's their site.
Driveshaft Specialist Inc
Old May 11, 2018 | 07:31 PM
db_tanker's Avatar
db_tanker
managed to find a 2 piece drive shaft with carrier for 350 shipped.
so next week we shall have it and go from there.
thanks!
D
Old May 16, 2018 | 04:18 PM
ojai150's Avatar
ojai150
thanks!
D
Brand new?
Old May 18, 2018 | 08:03 PM
db_tanker's Avatar
db_tanker
brand new
I will be installing tomorrow.
Old May 19, 2018 | 11:15 AM
db_tanker's Avatar
db_tanker
well got out there and started on it. got the old shaft out and began working on getting the new unit installed. (FYI...if you are going to do this...go at it from the passenger side...the gas tank and my belly became close friends...and I did have it on jack stands )
ran into this...
the old unit is hollow...new unit has a blind hole...not sure if I can go with a spacer or what...but instead I contacted the seller on ebay sending them the same pics and see what they say. I figure they have a different yoke piece and will just ship me that. I can put that on no problem.
ah well...drive shaft drama. :P lol
Old Jun 7, 2018 | 04:29 PM
blueovalandy's Avatar
blueovalandy
Just to relay my experience. I was able to press out my old staked in u-joints. I figured that I could just match up a replacement u-joint at the parts store. I was wrong. there is NO off the shelf u-joint that fits our staked in style drive shaft. I have a milling machine, so I was able to machine the yokes to accept a standard u-joint, but it was WAY more effort than what it was worth.
Andy
Old Jun 9, 2018 | 02:50 PM
db_tanker's Avatar
db_tanker
How was the balance afterward Andy?
I am worried about that and the main reason why I went with a new driveshaft.
I finally have the parts and just need to get the weekend "window of opportunity" to arrive. lol
Also the company that I got the new driveshaft from instead of sending me the yoke piece simply comp'd me the cost of the parts to my paypal account. Same same to me.
Old Jun 18, 2018 | 09:18 PM
merczephyr's Avatar
merczephyr
I recently pressed out the staked in U-Joints in my 2006 SCrew 4x4. I used the Balljoint U-Joint Press from Autozone (Rental), 1/2" Impact (borrowed a buddy's Snap On), put the shaft in a big vise, and worked the joints back and forth. Got them pressed out without cutting anything. Used a round file to smooth out the stake points. Pressed in Spicer 5-178X's. Full disclosure, I did bend the **** out of a Harbor Freight press on the first joint.
Old Oct 7, 2019 | 02:10 PM
gary riggs's Avatar
gary riggs
Any spacers
Any spacers? Just a direct fit after pressing the old one out?
Old Oct 16, 2019 | 06:08 PM
Trent Badon's Avatar
Trent Badon
I just replaced my shaft late September after seeing those darn stakes, and the oem replacement joints were 80 a piece from my research. They come with a tool to cut the stakes and each cap needs to be shimmed with a supplied shim in the kit. After all that I wondered if I wouldn’t have had to bring it somewhere to be balanced. Screw all that when a New complete shaft with greaseable joints 350.
2004 f 150 fx4 crew with 140 k.
twall_SD250
Oct 21, 2012 03:36 PM
broncobillyII86
Bronco II
13
May 24, 2006 01:47 PM
4x4kinda girl
Jan 20, 2005 09:26 PM
Beppy
Bronco II
Aug 31, 2003 11:02 PM
bdonalds
Sep 19, 2002 11:58 AM
