alternator light flucuates
Old Nov 8, 1999 | 04:26 AM
mike
Guest
Posts: n/a
hi, me again. iwas wondering if anyone has ever seen a alternator light flucuate on and off at idle.it wont do it at a higher rpm. i thought the belt may be a little loose, how about you?
Old Nov 8, 1999 | 10:10 PM
Mulletwagon's Avatar
Mulletwagon
More likely the result of a bad alternator or regulator or a heavy load on the electrical system. When the light comes on it means the battery is powering the electrical field in the alternator rather than the alternator powering the field itself. When enough juice is generated a set of contacts in the regulator are pulled open which disconnects battery current to the field and shuts off the light. Short term solution may be to up your idle or put a smaller pulley on your alternator. Might also have your alternator and regulator bench checked. HTH
Old Nov 9, 1999 | 02:25 AM
BigBrownTruck's Avatar
BigBrownTruck
