7.3 intermittent stall NOT CPS
The whole time reading this it reminded me of symptoms I chased.
have you inspected your wire harness for breaks ?
you should us a MM and ohm it out but a quick visual of the ICP, IPR and CPS wire runs off the main harness, within 3-4” of the sensor will typically reveal the issue.
Me thinks you will find something similar
you should us a MM and ohm it out but a quick visual of the ICP, IPR and CPS wire runs off the main harness, witching 3-4” of the sensor will typically reveal the issue.
Milwaukee1979F150
04-06-2012 07:48 AM
PowerstrokeJunkie
36
09-17-2008 10:16 PM
