7.3 intermittent stall NOT CPS
Old 04-21-2019, 09:02 AM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
Could add the pid for throttle % and IVS? WHat if u have a bad spot in your pedal causing it?
Old 04-21-2019, 09:25 AM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
The whole time reading this it reminded me of symptoms I chased.
have you inspected your wire harness for breaks ?
you should us a MM and ohm it out but a quick visual of the ICP, IPR and CPS wire runs off the main harness, within 3-4” of the sensor will typically reveal the issue.
Me thinks you will find something similar
Old 04-21-2019, 07:13 PM
yzf450motoxrider's Avatar
yzf450motoxrider
yzf450motoxrider is offline
It is included last column at 13.33% it hiccupped when I put it in gear from park to drive foot not on gas.
Old 04-21-2019, 07:20 PM
yzf450motoxrider
you should us a MM and ohm it out but a quick visual of the ICP, IPR and CPS wire runs off the main harness, witching 3-4” of the sensor will typically reveal the issue.
Thanks. I will ohm the injectors I figured they would be fine since they buzz tested ok. I will double check the other sensors. I know the ipr is good as the original cause of the stalling was the ipr pigtail which was replaced which solved the instant loss of oil pressure. now the rpm drops off first and the oil pressure actually goes up. I agree definently feels like an electrical issue.
Old 04-21-2019, 07:26 PM
carltonwebb
Should of put my glasses on. My apologies. I looked twice too. LOL
Old 04-28-2019, 05:09 AM
yzf450motoxrider
Pirate, where you the one who rebuilt your wiring harnes? Do you have a link to that thread? Thanks
Milwaukee1979F150
04-06-2012 07:48 AM
guyno78
11-26-2010 06:15 PM
mongo75
07-30-2010 12:41 AM
danskool
20
03-28-2009 08:31 PM
PowerstrokeJunkie
36
09-17-2008 10:16 PM
Quick Reply: 7.3 intermittent stall NOT CPS
