reverse sensor on full time
Old Apr 28, 2018 | 06:52 PM
st8yd's Avatar
st8yd
All of the sudden the reverse sensor has started beeping as soon as it is dropped in reverse. Push the button and it shuts off till next time. I have not done any modifications recently to possibly disturb something.
Any suggestions?
Thank you
Old Apr 28, 2018 | 07:41 PM
seville009's Avatar
seville009
One (or more) sensors probably have gone bad
Old Apr 28, 2018 | 10:05 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Have you tried cleaning them? Fixed mine
Old Apr 29, 2018 | 07:24 AM
st8yd's Avatar
st8yd
Ya but there not dirty.
Old Apr 29, 2018 | 08:22 AM
msuser92's Avatar
msuser92
Any suggestions?
Thank you
Mine has done the same thing before. I narrowed down which sensor was causing it (found info in tech folder) and just wiggled the wiring on that sensor and it fixed it for a while. It started doing it again, so I need to unplug it and check the condition of the plug.
Old Apr 29, 2018 | 08:49 AM
st8yd's Avatar
st8yd
Can you post a link? the only thing I saw was changing the reverse sensor speaker. Thanks.
Old Apr 29, 2018 | 09:08 AM
msuser92's Avatar
msuser92
Sensor procedure
From the thread: https://www.ford-trucks.com/forums/9...ways-on-2.html
Post #24
Turn key forward to accesory position not running put truck in reverse go to rear of vehicle and the sensors that are working you will feel a pulse or tick and can actually hear them slightly, by touching each one individually the one that does nothing is bad. This is how i fixed mine and now works great I am AWESOME mine was far left one that was bad no expensive tool needed good luck!
dawson735
Oregon Chapter
Oct 28, 2012 09:50 AM
Larry NCKS
Apr 16, 2011 10:45 PM
REDFORDFX4
2004 - 2008 F150
Sep 1, 2009 05:59 PM
ajmommie
Apr 12, 2005 03:31 PM
