Part identification???
Old Apr 26, 2018 | 02:26 PM
Dennis-'s Avatar
Dennis-
Hi guys,
i was pulling apart a speedo cluster I acquired from a f600 and noticed that it had a box that attached in between the start of the speedo cable and the back of the speedo. I’m wondering if my 59 f100 is missing this or if it is just a f600 thing.
Old Apr 26, 2018 | 05:02 PM
G-Force junky's Avatar
G-Force junky
That’s a mini gear reduce. It’s for using different transmissions with the same gauge cluster.
Old Apr 26, 2018 | 05:24 PM
matthewq4b's Avatar
matthewq4b
Actually I think this a Speedometer mounted speed governor. Hence the electrical connections.
ND will be able to tell us for sure.
Old Apr 26, 2018 | 05:27 PM
G-Force junky
Ahh I should have taken a closer look. Didn’t notice the wires.
Old Apr 26, 2018 | 09:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Dennis-
I was pulling apart a speedo cluster I acquired from a F600 and noticed that it had a box that attached in between the start of the speedo cable and the back of the speedo.
I’m wondering if my 59 F100 is missing this (it isn't). It's just a 500 and larger series truck thing.
You won't find this puppy on a F100/350.
B9TF-17294-E (replaced FEM-17294-A) .. Speedometer Cable Adapter Assy - Contains built in solenoid - Use with Two & Three Speed Rear Axles.
1957/72 F500/1100; 1957/77 P500; 1963/69 N/NT500/1100
Old Apr 27, 2018 | 03:22 AM
Dennis-'s Avatar
Dennis-
Thanks guys,
excuse my inexperience, but what exactly is its function? Would it act similar to an overdrive govener and send a signal to engage the 2/3 speed rear end at a certain mph?
Old Apr 27, 2018 | 10:05 AM
eberhama's Avatar
eberhama
It compensates for the different gear ratios of a multi speed rear axle, making sure the speedo reads correctly.
Old Apr 27, 2018 | 01:29 PM
Dennis-'s Avatar
Dennis-
Ohhh darn, so simple. Thanks for that!
robinsoneb
Dec 12, 2018 08:35 AM
Russ74
Feb 12, 2018 01:18 PM
Amish65F100
Apr 5, 2017 08:37 AM
78 Ford F150 460
20
Feb 4, 2014 09:25 PM
I-6 Power
Nov 28, 2012 07:51 AM
