Once, when I removed the gauge cluster from my 1979 F100, I had to remove the speedometer cable from the back of the cluster. When I put the gauges back in, the speedometer needle now jumps around until the truck speed is about 35 MPH, then it becomes still and reads the current speed just fine. So why is it not reading correctly? The cable is good, but when my boss looked at it, he thought that it may not be fully connected at the back of the cluster or at the side of the transmission. Any suggestions?
After removing mine in my 73 i never got it fully connected and that,s what mine did. They are a little hard for me to do because of not having a lot of grip . Grip the locking device and push in hard , after releasing it, pull out on it ,if it stays it's good.__
You're talking about at the back of the gauge cluster, right?
disconnect cable from back of speedo, shoot some wd-40 into the cable to help lube then reconnect at back of speedo, they can be a bit of a chore to get on and seated
Sounds like your speedo cable is encountering a bit of friction. Don't use WD-40 or anything like that, it'll just ruin the cable. Go to the autoparts store and get you a little thing of graphite oil.
I apologize for my inexperience, but what is graphite oil? And how do you use/apply it?
