2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
5.4 timing
Old Apr 21, 2018 | 03:18 PM
brad.82's Avatar
brad.82
5.4 timing
Hey guys,
I got a 2008 Ford expedition el 5.4 3 valve. Recently the timing guides exploded and clogged the oil pick up screen, I have cleaned everything up and replaced the guides, chain, VVT sprockets, high pressure oil pump, and installed the ratcheting chain Adjusters. All was great for 3 or 4 weeks😬 now when under a load (like driving up steep hills) it starts ratcheting really bad like the VVTs aren't working. Then I get a #5 misfire, I have swapped the coil pack with another one and I still get the same code.. When it's ratcheting and shaking, if I put it in park and rev It up it settles out until I put it under a load again.. Not sure what I missing lol
thanks in advance!
Old Apr 21, 2018 | 06:56 PM
pdqford's Avatar
pdqford
Originally Posted by brad.82
Hey guys,
I got a 2008 Ford expedition el 5.4 3 valve. Recently the timing guides exploded and clogged the oil pick up screen, I have cleaned everything up and replaced the guides, chain, VVT sprockets, high pressure oil pump, and installed the ratcheting chain Adjusters. All was great for 3 or 4 weeks😬 now when under a load (like driving up steep hills) it starts ratcheting really bad !
Could you describe “ratcheting”?
Then I get a #5 misfire, I have swapped the coil pack with another one and I still get the same code.. When it's ratcheting and shaking, if I put it in park and rev It up it settles out !
Swap the plug with another hole, the boot to another hole, and the injector to yet another hole and see if the problem follows.
Old Apr 22, 2018 | 09:29 AM
brad.82's Avatar
brad.82
It shimmies and Shakes as a normal misfire but it has the knock like the VVT sprockets aren't working
so yesterday I swapped ever thing around and I tried it this morning, same thing.. When it shimmies and shakes, if I put it in park and floor the gas to the rev limiter kicks it settles out and runs fine.
Old Apr 23, 2018 | 10:38 PM
pdqford's Avatar
pdqford
After swapping around is it still throwing P0305?
Old Apr 26, 2018 | 07:00 AM
brad.82's Avatar
brad.82
Yeppers, I get the po305 but after swapping i now get a po345 and po349 when its running rough.. Again it only does it when under a load ( Pushing it to climb a steep hill, flooring it to clean it out ) other then that it runs great..
brad.82
Modular V8 (4.6L, 5.4L)
May 16, 2018 08:06 AM
oldstylefseries
1997 - 2003 F150
Jan 15, 2018 06:26 AM
Pete Kildow
Feb 26, 2016 03:25 PM
skinsey
Oct 7, 2009 09:23 PM
