5.4L timing.
Old Oct 6, 2009 | 06:15 AM
skinsey's Avatar
skinsey
5.4L timing.
Does anyone have a picture or diagram for setting the timing on a 2004 5.4L?
(((the engine was rebuilt...runs like a champ over 1500rpm's...but when idling it idles rough almost like a vacuum leak (cant find any)...any suggestions?)))
Old Oct 7, 2009 | 05:55 PM
torkum's Avatar
torkum
If the timing was off it would run worse over 1500rpm [unless you have a 3 valve witha cam phaser acting up]'. Check your IAC.
Old Oct 7, 2009 | 06:06 PM
skinsey's Avatar
skinsey
all codes point to a mis on cyl #4. i checked voltages at the c.o.p and the injector and it is the same as all the others. so its either cop or an injector. do the injectors typically go bad on these engines? its a 2.V
Old Oct 7, 2009 | 09:09 PM
torkum's Avatar
torkum
On a 5.4 2V 9xs out 10 its the COP. Switch the COP to another cylinder and see if the code moves to that cylinder.
Old Oct 7, 2009 | 09:15 PM
skinsey's Avatar
skinsey
cool i'll try it tomorrow morning..thanks. i'll let you know
Old Oct 7, 2009 | 09:23 PM
skinsey's Avatar
skinsey
do i unhook the battery for a while to erase the codes?
JKTX21
1997 - 2003 F150
Feb 1, 2009 01:28 PM
mark4564321
2004 - 2008 F150
Apr 3, 2008 06:16 PM
ledfoot
Oct 9, 2007 03:38 PM
BlueZack
Nov 29, 2004 02:18 PM
Ultramagdan
1997 - 2003 F150
Oct 26, 2002 06:47 AM
