Od, light flashing
Old Apr 14, 2018 | 05:05 PM
Bigpetetow's Avatar
Bigpetetow
Od, light flashing
First time posting, hopefully I can get some advice and at least point me in the right direction. Well I just bought a F350 7.3 idi that’s been sitting and the od light flashes from the start. According to the previous owner he had repaired/rebuilt the tranny and never used it it’s been sitting for 3 years, the truck started instantly with two fresh batteries , and when I went to drive it it has a first , second and reverse gear but no third or od. I went to do the paper clip test in the obd1 port and the od light on the shifter stopped flashing when the clip is inserted. I couldn’t pull a code , no service engine soon light ever flashed. Does anyone have any idea what might be the issue?
Old Apr 14, 2018 | 05:25 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You're going to need the codes. Here's the complete procedure: https://www.troublecodes.net/ford/
Old Apr 14, 2018 | 05:48 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Although that works,it's not very fun to do lol.You can grab an old code scanner for these rigs very reasonably.
INNOVA 3145 Ford Digital OBD1 Code Reader INNOVA 3145 Ford Digital OBD1 Code Reader
Old Apr 14, 2018 | 07:47 PM
Scott in TX's Avatar
Scott in TX
agree with others, spend $20 and buy the code reader, it's just easier,
also you won't see any service needed lights, only the o/d flashing
Old Apr 14, 2018 | 07:59 PM
Bigpetetow's Avatar
Bigpetetow
All this advice pointing me in the same route, buying a obd 1 scanner it is!!! Thanks gentlemen I’ll be posting as soon as I find the result of the trouble shooting
Old Apr 15, 2018 | 01:25 AM
Bigpetetow's Avatar
Bigpetetow
Ok I bought a obd1 scanner and it gave me 6 codes the first one is 23 tp out of range I’m going to recalibrate this first, the other codes are all tranny related, 91-93-94-99,,,would it be better for me just to replace the solenoid pack/ valve body or any other advice?
Old Apr 15, 2018 | 09:34 AM
FORDF250HDXLT
23 you'll always get if you don't hold the accelerator (or linkage) wide open during the whole test.That's likely all that is.If you did hold WOT during the scan,then disregard.Replace it (if over 50k miles and or unknown miles,or during a reman) and read here:
A/T - E40D FIPL (TPS) Sensor Trouble Shooting & Adjustment (Diesel Applications Only)
The other codes point to a failing and or dirty solenoid pack connection.It's highly likely,though not limited to,that your bulkhead connector has failed.Read here:
E40D: The Importance Of A Clean Trans Harness
GulfcoastSD
Nov 12, 2013 01:14 PM
luvemhot
13
Jul 26, 2013 01:21 PM
damons
31
Jun 27, 2012 09:56 PM
Cobra93svt
Sep 2, 2008 01:12 PM
SpoolingF-350
31
Dec 6, 2005 09:19 PM
