OD Light Flashing
Old Jun 20, 2012 | 10:06 PM
damons's Avatar
damons
OD Light Flashing
I never had this problem until I got my DP Tuner, now I have noticed twice while hauling my camper that the OD light flashing after a while and the only want to get it off is to put in reverse, or turn off truck and turn back on. I hauled my camper MANY times before tuner, NEVER a flashing OD light. I can push the OD button and it seems to work fine, tranny seems to shift fine. I read somewhere online that a faulty alternators could do this, true??? Help!
Old Jun 20, 2012 | 10:33 PM
BigAlsPSD's Avatar
BigAlsPSD
There are many causes, sensors are sensitive to voltage spikes and fluctuations. What is the code?
Old Jun 21, 2012 | 12:08 AM
damons's Avatar
damons
I dont think I have a way of getting code unless it's flashing in a code, the actual OFF light on the shifter is the one flashing, if that makes a difference.
Old Jun 21, 2012 | 12:10 AM
BigAlsPSD's Avatar
BigAlsPSD
You would have to pull codes with a scanner...being a transmission code, a free parts store code reader would probably work though, unlike with the engine needing to have AE or the like.
Old Jun 21, 2012 | 12:20 AM
damons's Avatar
damons
Youre saying auto parts store will read code for free?
Old Jun 21, 2012 | 12:22 AM
BigAlsPSD's Avatar
BigAlsPSD
Yes, all the big auto parts stores by me will, such as Oreilly, AutoZone, and Advance. Normally this will not work when you have a SES light or something with the engine but it could work with a transmission code.
Old Jun 21, 2012 | 01:11 AM
big poppa's Avatar
big poppa
A Superchips handheld tuner-codereader will work too. If you can't find somebody with one, check Sinister diesel or Clay at RiffRaff, worth the money (100.00) just for the code reading capabilities.
Old Jun 21, 2012 | 08:20 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
If the OD light was blinking, you have a stored code. The auto parts store readers can't read our trans codes.
Old Jun 21, 2012 | 10:14 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes they will, and they will tell you that there are no codes. They are not capable of reading Ford transmission codes, but most of them don't know that.
Old Jun 21, 2012 | 11:25 AM
damons's Avatar
damons
Does anyone have an opinion, could it be bad?
Old Jun 21, 2012 | 12:13 PM
GonzoCSU's Avatar
GonzoCSU
My buddys did this and it just so happened to start a week after he got his chip. Turns out it was a faulty temp sensor. Probably something simple. Get the codes pulled and we can help more.
Old Jun 21, 2012 | 12:22 PM
thomabb's Avatar
thomabb
The only time mine ever did that was when I had to downshift to 1st to snake down a steep mountain road (I use the term 'road' loosely) with my 5th wheel. It never came back, so I figured I tripped some limit in the tranny somewhere. The light stopped flashing when I shut down, and never came back.
It's possible your tuner is pushing the tranny beyond some pressure or temp limit and is throwing a code.
Old Jun 21, 2012 | 01:58 PM
BigAlsPSD's Avatar
BigAlsPSD
I had never tried it, since I have snap on, but thought it could be worth a shot. Now I know better, thanks guys.
Old Jun 21, 2012 | 02:01 PM
BigAlsPSD's Avatar
BigAlsPSD
I would say the "opinion" is to find out what the code is, and proceed from there. It could be tuning related, it could be something failing...Only a few times have I had a trans code once was because my switch for the 4X4 low range was stuck on, lamp was burned out, even though the transfer case was in 2wd, after a few miles it threw a code. Then my most recent issue with a 2-3 shift error which I have yet to resolve.
Old Jun 21, 2012 | 02:25 PM
89LX306's Avatar
89LX306
Where are you located? You might find someone on here with AE that will help you out. If you are near Houston I'd be glad to hook it up for you.
