Overdrive Light?
Old Dec 1, 2005 | 07:41 AM
SpoolingF-350's Avatar
SpoolingF-350
Overdrive Light?
Today on the way to work getting on the highway It started doing a one wheel peel . After that the overdrive light started coming on and off, all the way to work, I turned it off and back on and it still did it. Does any one no what these means?
Thanks Derek
Old Dec 1, 2005 | 07:44 AM
dunbar15's Avatar
dunbar15
do you have your manual ?? I know its a trane error, not sure exactly what
error it means. I'm sure someone in here will give you alot more info than this, but I remember seeing that in my manual..
Old Dec 1, 2005 | 08:44 AM
Kwikkordead's Avatar
Kwikkordead
Probably have some crud on your VSS after peeling out. Take it out and clean it for starters, or simply replace the $20.00 part.
Old Dec 1, 2005 | 09:05 AM
Casey's Avatar
Casey
A flashing OD light means SOMETHING is wrong with the transmission system. It could be the VSS, or it could be about 50 other things.
The only way to know is to have the code read. When the light flashes a code is stored in memory. It will stay in memory even if the light stops flashing.
In my opinion it is a waste of time and money to change parts without knowing what code was set.
Old Dec 1, 2005 | 09:08 AM
Kwikkordead
Thank you for that reminder Casey.
Old Dec 1, 2005 | 09:08 PM
SpoolingF-350
Would I be able to use my superchips to check it? The light went off as soon as I started the truck back up later, but I want to check on this for sure.
Thanks Derek
Old Dec 2, 2005 | 10:24 PM
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
Yes , A Superchips Microtuner Should Be Able To Read Any Code That Has Been Set On Your Truck. There Should Still Be A Readable Code Stored Even Though The Od Light Is No Longer Blinking.
Old Dec 3, 2005 | 09:29 AM
Black88GT's Avatar
Black88GT
Once apon a time I tried to spin my tires on takeoff, and they didnt spin. LOL! My OD light blinked, untill I restarted it, then I never saw it again. That was over a year ago, so I figured the tranny was telling me dont play with me
Old Dec 3, 2005 | 09:48 PM
maevans's Avatar
maevans
[QUOTE]Once apon a time I tried to spin my tires on takeoff, and they didnt spin. LOL! My OD light blinked, untill I restarted it, then I never saw it again. That was over a year ago, so I figured the tranny was telling me dont play with me
Once while pulling my 12,500lb toy hauler, My od light blinked when i started backup after she was shut down for over 4 hours, I turn the truck off for about 1 minute then restarted, the light when off and never came back on
Old Dec 3, 2005 | 09:51 PM
amish77's Avatar
amish77
might jsut be the trucks way of telling you you're overloading it. Sure as heck won't hear themotor telling you it's overloaded.
Old Dec 4, 2005 | 11:50 AM
BadAss01F250's Avatar
BadAss01F250
i had the exact same problem you did, after doin too many burnouts and doggin it my overdrive light kept flashing on/off and wouldnt go away. it is definately a transmission problem. with mine, 2nd gear was completly ripped out and had to replace the whole tranny! ive learned my lesson since then
Old Dec 4, 2005 | 02:07 PM
4X4 IN REFUGIO
Smile
I REALLY THINK THAT READING OR CHECKING THE CODES THAT ARE PROBABLE SET OR SHOULD BE IS DEFINETLY A GOOD STARTING POINT TO FIND OUT WHAT MADE YOU OD LIGHT FLASH.
READ THEM OR HAVE THEM READ AND LET US KNOW WHAT YOU COME UP WITH.
THEN SOMEONE COULD MAYBE HELP YOU OUT AND/OR THE REST OF US MAY LEARN SOMETHING FROM YOUR SITUATION.
Old Dec 4, 2005 | 03:13 PM
amish77's Avatar
amish77
Why Are We Yelling
Old Dec 4, 2005 | 07:11 PM
SpoolingF-350
Superchips programer gave me 5 numbers
p0603
p0478
p0470
p1211
p0782
I think that I may have to call the dealership or a local mech. shop to know what the codes mean, I cant believe that there was 5, unless I dont know how to check them on the superchips.
Old Dec 4, 2005 | 07:42 PM
amish77's Avatar
amish77
haynes should be able to tell you. 15 bucks for a manual.
