Window Drooping
Old Apr 13, 2018 | 10:30 AM
man7sell's Avatar
man7sell
Question Window Drooping
My passenger door window won't stay all the way up. It slowly droops down about an inch every time I drive or even when parked for a couple of days. Any thoughts or experience with this problem?
Thanks
Paul
1963 F100
Old Apr 13, 2018 | 12:15 PM
TA455HO's Avatar
TA455HO
Lead Gopher
That's got to be the regulator that is worn out. Can't be the inside handle itself or the glass and there is nothing else that moves between them. Here's one vendor that makes and sells them, at least. Says made in the USA.
Door Window Regulator | Dennis Carpenter Ford Restoration Parts
Chad
Old Apr 13, 2018 | 12:27 PM
man7sell's Avatar
man7sell
Door Window Regulator Dennis Carpenter Ford Restoration Parts
Chad
Thanks Chad. Out of stock but I better check that the spring is attached first.
Old Apr 13, 2018 | 12:30 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Ya, they say restock in two days. I couldn't see any way to tighten the spring but you might have better luck. If you find a way let us know.
Chad
Old Apr 13, 2018 | 02:21 PM
Crop Duster's Avatar
Crop Duster
Window regulator?
I don't know what that thing is actually called, but it is sort of a one way clutch. You can drill out the rivets and get inside to inspect it and clean it up. The one on the right has been cleaned the one on the left is what you will see when it's apart. If that spring clutch in there isn't working the window will not stay up.
Old Apr 13, 2018 | 02:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old Apr 13, 2018 | 03:20 PM
charliemccraney's Avatar
charliemccraney
There are usually some used ones on eBay
Old Apr 13, 2018 | 04:28 PM
NumberDummy
NOS:
There's a right side window regulator (C1TZ-8123200-B) on ebay for $69.00.
Plus:
NOS PARTS LTD has 1 = 972-937-2201 // NOS PARTS SOURCE has 1 = 913-220-5746. // GREEN SALES CO. has 11 = 800-543-4959.
Carpenter has the left side (C1TZ-8123201-B), but no Ford dealer or obsolete parts vendor has any NOS
Old Apr 14, 2018 | 04:57 AM
Spatzboy's Avatar
Spatzboy
Just received one from LMC
Old Apr 14, 2018 | 04:38 PM
daveengelson's Avatar
daveengelson
Appears there's a difference of approx. $20 between used ebay and new; IMO I would not purchase used regular never know what U'v purchased particularly considering the difference in price; it would be similar to purchasing used hood hinges. Most importantly, check condition of the knurled spline for the handle, mine was stripped and as last ditch effort took mini rectangular file and cleaned the splines, this was 15 years or so and works fine.
Gicknordon
16
Jul 12, 2017 06:50 PM
jotram
Apr 15, 2016 04:08 AM
southwindva
Apr 24, 2015 02:09 PM
Tedster9
Nov 14, 2011 11:46 AM
jhromy
Apr 7, 2004 10:07 PM
