Sponsored by: Innova
system in the bed..
Old Sep 17, 2003 | 11:04 PM
c_ville's Avatar
c_ville
system in the bed..
i have a 2004 ranger edge supercab and i dont want to lose the back seats so im really wondering where to put the system. im thinkin the best bet is in the bed and was wondering if ne 1 has installed somthing similar and has pictures or any info.
my first post btw, board seems to be pretty hot.
Old Sep 18, 2003 | 08:42 AM
f-350dude's Avatar
f-350dude
system in the bed..
well i dont have expierence with it but i know someone that has put a system in the bed of there truck. the first thing is that u should have a conopy if u dont have one of them then i wouldnt suggest doing it.
there also is another way ha i now of alot of the lowrider truck people do it is u make a box out of metal and u weld it to ur bed and just make sure there is no leaks or anything alon those lines.
Old Sep 18, 2003 | 09:34 AM
PrPlayboy's Avatar
PrPlayboy
system in the bed..
system in the bed..
For a minute there I thought some one put a system in there real bed.....lol
There are ways to make small boxes fit with out having to go the route your talking about. There are alot of people here with rangers........ come on tempe and luvdeftonz....... that can help you figure a way to get subs in your truck and keep your seats.
Old Sep 18, 2003 | 05:33 PM
c_ville's Avatar
c_ville
system in the bed..
the deal on what im getting is unreal and i need to make up mi mind soon before he gets choked that im taking to long to make the call.
2 twelve inch kickers w/ a box and a 1200 watt amp for 450.
i dunno the brand of amp but he said its retail around 1250...i was also wondering if ne 1 can recomend a deck for that set up. i was looking it this one that had dolphins and other images on the display but i cant remember the name of it.
(its all canadian currency by the way)
ne help with either of my questions is greatly wanted/appreciated
Old Sep 18, 2003 | 10:45 PM
optikal illushun's Avatar
optikal illushun
system in the bed..
Pioneer DEH-3500 or DEH-5500 or Alpine (cant remeber the model number) would be my choice. u could also go eclipse or clarion or nak or...
Old Sep 20, 2003 | 12:45 AM
c_ville's Avatar
c_ville
system in the bed..
ill look into those decks. thanx optikal
but im still wonder what i should do with the subs/amp... does ne 1 in this huge forum have any info they feel like sharing?
Old Sep 20, 2003 | 02:04 PM
mzimmers's Avatar
mzimmers
system in the bed..
First of all...don't get too eager about the deal this guys offering you. The world is *filled* with cheap used audio equipment...another deal will come along if this one gets past you.
As far as putting equipment in the bed...I'm assuming you don't have a top over the bed...is this correct? If so, you'll have a *lot* of work to do to keep the electronics protected. You'll need a waterproof box (and you'll still need to put dessicants in from time to time as moisture does collect in boxes), waterproof wiring, and I can't imagine what you'd do to protect the subs and still hear them.
You don't need huge equipment for a Ranger...it's a small cabin. Look at stealth boxes for a sub (and one good sub is plenty) and amps with smaller form factors. It will be a more professional installation and you'll thank yourself for it in the long run.
Old Sep 20, 2003 | 07:28 PM
c_ville's Avatar
c_ville
system in the bed..
thanx for the help mzimmers.. but i plan on getting a lo riders toneu cover for the box so it wont be that big of a deal.
Old Sep 22, 2003 | 03:07 PM
mzimmers's Avatar
mzimmers
system in the bed..
OK...I'm not sure I know what a low rider tonneau cover is, but hazarding a guess, it's not going to be enough all by itself. It's not enough to keep the rain off the equipment. You need to try to prevent excessive humidity from penetrating the electronics. Heat and (in extreme cases) cold can be enemies of amps and especially subwoofers.
Consider a smaller Husky box and find a way to dessicate it. Use weatherproof grommets the kind that screw together) to pass the wires through it.
You may want to mount equipment using rubber bushings to reduce vibration. And IMO it's still best to find a place inside for a sub, even if that means going with something a little smaller than you were originally hoping for.
Good luck and keep us posted...
Old Sep 22, 2003 | 10:54 PM
optikal illushun
system in the bed..
if ur gunna do a full blow through ur gunna need some kind of boot to run from the cab to the bed. i have seen a few people run a speaker box into the bed and make a metal shell around it.
Old Sep 23, 2003 | 09:47 PM
c_ville's Avatar
c_ville
system in the bed..
forget all that in the bed business. its way too much work just to save some seats that i dont really need all that much. thanx ne ways tho guys
CortStrasser
Jan 8, 2015 07:05 AM
bryanmartin
May 31, 2012 11:06 PM
Norcalboris
Sep 20, 2009 11:51 PM
'02STROKER
Oct 13, 2007 03:25 PM
