Gear selector stuck in gear and wont shift.
Hello,
I have a 1997 f350 7.3 automatic. We were taking salters off trucks and guy broke steering column lever while attempting to change out of park. Well I cahnged that, fix it. Snapped the column tube. So I put a new one back in and the gear lever was would not bundge, I got under the truck(tires chalked), had a guy upstairs, (key was stuck in ignition by the way) so he was turning key on and braking as i was trying to maunal switch the gear lever that goes through Nuetral safety switch and it will not budge what so ever. So i was thinking NSS, (no codes, no CEL, no OD light blinking) I had to brake the damn thing off, fry the remaining circle nylon plastic ring. Finaly got it off. I can not line this new switch up right with out getting it in neutral. I can not get this lever shaft to change gears. I tired jacking rear of truck up to releive pressure, towed the truck forward 5", for the same concept. No luck.. Pulling fuses while I sat there on the phone for the hell of it. I posted on another forum but only one reply so far. Do I have to pull the pan? if so, what am I looking for? parking prawl or that parkig pin? Thanks again.
Took
Dropped the Pan on tranny as I was removing filter this metal clip wth a roller on it fell right on my head. Anyone know what this is, pic attached.
Fixed.
Thanks everyone for all of their help. It was the detent spring,https://www.google.com/search?q=dete...obile&ie=UTF-8 In that link. Now the "e clip" was for the manual lever valve rod, it had a shift kit on it and that e clip I belive is part of an upgrade. The detent spring got stuck in gear selector. Dropped pan, 8 mm bolt. Simple. Put new NSS, steering column tube assembly, Tran filter, detent spring, and e clip I bent back and pushed on the manual lever valve rod thing. It got in a little area by arm that is connecting to rooster tail gear selector piece. Lined up NSS, can't get the pigtail to click in to new sensor but it came with a new pigtail. That suppose to be for another day.... Batteries back together and turned key, started immediately. Had to make a few adjustments to steering gear selector . shift amazingly simple.. Thanks again.
leftylucy64
General Diesel Discussion
04-14-2018 07:40 AM
uad_chaps
03-08-2011 05:57 PM
wojo1989
12-23-2005 03:03 PM
