Hammer gnome?
Old Apr 14, 2018 | 10:01 AM
Highboy46's Avatar
Highboy46
Also it's doesn't faster or slower with speed or engine rpm but instead with engine load if that makes sense. I think that rules out rotating assemblies. But maybe not.
Old Apr 14, 2018 | 11:51 AM
meangreen92's Avatar
meangreen92
If it's load dependent, then it probably is something getting moved by torque, and causing a bind or interference.
Have you tried different transfer case selections to see what the noise does?
Can you get it to occur by holding the brake and giving it some gas?
If you could get it on a frame lift, you might be able to get a better idea - especially if the brakes can duplicate the conditions for the noise.
Old Apr 15, 2018 | 02:16 PM
User 71024's Avatar
User 71024
What is the truck?? Sounds like it might be the front U-joint hitting the floor.
Old Apr 15, 2018 | 07:56 PM
Highboy46's Avatar
Highboy46
ujoints all seem to be in good shape. It's a 1975 f250 4x4.
ultraranger
20
May 15, 2017 06:10 PM
jvmcc
Oct 24, 2015 11:41 AM
lowtrkn2k
Sep 29, 2012 03:59 AM
FordOwnerJoey
Oct 18, 2011 03:54 PM
bobj49f2
17
Jul 21, 2006 02:15 PM
