Module Reprogramming Do it yourselfer!
Just wanted to reach out to those Guru's who are able to flash calibrations and or reprogram the modules in their Ford's/Lincoln's and Mercs.
I am pretty sure the Elm Adapter i currently own can read them, has the switch for both HS and MS can bus feeds. also been told i should be able to reprogram the modules and or update them.
Software i've been using for clearing the basic stuff is Torque. love it but limited on what it actually will do.
So I've invested time into obtaining Ford IDS and FDRS. however now the dilemma... They require Activation Codes against their live server.
My issue is which one do I need. I can get a 2 day license for the IDS/FDRS for I think 50$ (does this option allow the reprogramming of the modules)
or Does the Full IDS suite with a 2 day license of 150$ allow this option too. Or is there a way to obtain the modules free based on my VIN and a program i can then use to reprogram them from there. I also am looking into ForScan for Windows.
I do understand I may be able to activate that for use personally for free? is this correct? if so where do I find that.
If you guys could please spoon feed the answers on this topic I'd appreciate it. time to research has been limited at best.
Again the main reason for this is : I have an 04 Expy EB. its had a traction control issue for a very long time and was told it needs to be reprogrammed by the dealer and now I understand if I have the vin and a place to get the file I can flash it myself saving a trip to the dealer. BTW, they are charging me 150 to re-flash it.
Any help would be greatly appreciated.
Bill
Location is Bristol PA 19007
There is an SAE standard for reprgramming, but you have to buy stuff from some company -- the stuff includes any licenses etc that are required.
There are a couple of guys that visit here that are shop owners -- so they probably have more info. You could also try asking your question in the forum section that covers your truck -- just go to the main page and scan for the section you need.
If you do try it yourself, be sure that you know what you're in for. The dealer charge might be cheap compared to what they might charge if somehow you screw it up.
Not trying to be a downer, but the companies don't seem to really make this easy. I'd be glad to find that I'm wrong about that, but I don't think that I am.
Good Luck,
hj
Saved me 150 at the dealers local to me. why i didnt look into this sooner i dont know.
All done and pretty easy too.
Projectsho89 - As you stated you are correct, Forscan was able to read the modules and correct it via the as built values already stored in the system. loaded that and calibrated.
Do have a question.:
I down loaded the as built data from Ford and it came in a .AB file Curious if i need to break it down to the individual modules? or if it can be imported in its current config and allow the system to read and pick what it needs to reset. how do you load the Ford AB file and or modify it in forscan.
I do have the IDS software but i dont have a valid license for it so i cant load it.
Alot of ForScan users there that would find this very interesting.
he was going to send me the info on the process and as of yet hasn't. I think that has
to do with him being busy. The issue I run into when trying to program or reprogram is
access to the needed files. I will send a message to the person and see if he has
some time to fill me in.
