Removing windshield trim
Old Apr 9, 2018 | 01:41 PM
madpogue's Avatar
madpogue
Originally Posted by McLeod
Don't bet on it.
Just trying to save you money and frustration, but knock yourself out!
What's so hard to believe about a cab gutter leaking. They're notorious for the seam sealer drying out and letting water in. Seen it on two of our three trucks, and just waiting for the shoe to drop on the third one.
Originally Posted by LARIAT 85
What is that tool called, and where can I find one?
Trim tool. Harbor Freight has a whole kit including that ^^^^^ one, for less than $10 IIRC.
Old Apr 9, 2018 | 10:44 PM
McLeod's Avatar
McLeod
My point exactly.
My "don't bet on it" was in reference to it "being another battle" because it could be the current battle he is suffering.
Often times the water is getting in where you least suspect it.
OP should figure out WHAT is leaking before replacing the windshield with the assumption that it is the problem.
I made something similar out of a robust piece of sheet metal.
fordbozo- see if this helps you with the trim removal - courtesy of Steve83
This and the next few pages:
1983 Ford Bronco General Purpose Pics picture | SuperMotors.net
Old Apr 10, 2018 | 02:07 PM
95fiveoh's Avatar
95fiveoh
Yeah, you can get that tool from harbor freight or any Auto body supply shop should be able to get you one. If I were you, Id pull the headliner, and check around just to be safe, and avoid being a parts changer.
Old Apr 10, 2018 | 07:27 PM
McLeod's Avatar
McLeod
On one of my Fords, the roof gutter was leaking and it was coming out about 4 inches down on the side of the windshield.
Even with close examination, it looked like the windshield was leaking,, but reality of it was water was traveling down the pinch weld on the A pillar.
Old Apr 20, 2018 | 02:09 PM
fordbozo's Avatar
fordbozo
While I sincerely appreciate all the ideas, water is dripping from the very top of the windshield down onto the rear view mirror and also conveniently directly into the steering column’s key hole. I seriously don’t know how this could be a gutter leak. Unless the law of gravity has been repealed lately, the windshield is leaking. An extra bit of rubber door gasket fell off while I was taking the visor off. This will need to be replaced. This is below the gutter and is a problem that just showed up and has no baring on the current leak.
I currently have a sheet of plastic over the dashboard. If this is a gutter leak then I need to start buying lotto tickets.
I just want to reiterate. This is not some water leak I can’t find. This is a water leak that requires me to cover the steering column and have a spare towel to dry my legs, face, and dash when it rains. The visor has been removed and it’s holes have been sealed. The windshield is leaking.
Old Apr 20, 2018 | 06:08 PM
McLeod's Avatar
McLeod
Well, only YOU can determine where it is leaking. We're too fdar away.
This is the first I have seen where you are more specific on WHERE it is leaking.
You have all ready stated that 2 glass companies have told you that it IS NOT the windshield.
Have you tried the soapy water and air hose yet?
Old Apr 30, 2018 | 12:19 AM
fordbozo's Avatar
fordbozo
Old Apr 30, 2018 | 12:44 AM
fordbozo's Avatar
fordbozo
my only point is everyone that has looked at my truck has told me it’s not the windshield. After reviewing the thread you have convinced me to try the soapy water approach. I’m pretty convinced it’s the windshield after removing the visor as a possible source of the leak. Everyone told me it was the visor. It’s not the visor.
I’ve been trying to make some headway on my two current truck problems and neither can get my full attention. The leak problem is the most difficult and the most pressing. I’m going to take your soapy water advice. I’m not sure I can pull it off, but It can still theoretically work even in the rain.
Old Apr 30, 2018 | 07:55 AM
McLeod's Avatar
McLeod
A heavy rain will dilute the soap too much and not work.
A light rain may be okay but doing it when dry would be the best.
Did you figure out how to get your w/s trim off?
jmadsen
Jun 2, 2010 11:24 AM
netscaner
Sep 9, 2008 05:48 AM
Rodney9865
Sep 20, 2004 02:46 PM
My Ford Truck
Mar 22, 2003 08:45 PM
emboyd
1978 - 1996 Big Bronco
Mar 4, 2002 07:29 PM
