shock finding resource
Old Mar 31, 2018 | 10:48 AM
zagamuffin's Avatar
zagamuffin
Hi all,
Im bagging and Jag Irs/Ifs ing my 55 and am looking for shocks with @ 10" of travel.Does anyone have a link to a site where i can find specs for moderns cars shocks specs so i can fit modern shocks off the shelf.
cheers
zagamuffin
Old Mar 31, 2018 | 10:59 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I downloaded the sheets below back in '11. Easy to cross reference from Monroe to other brands. I haven't been able to find a more current version.
File Type: pdf
Old Mar 31, 2018 | 02:33 PM
Mr. Ed's Avatar
Mr. Ed
I used www.monroe.com when I was looking for air shocks for my '79 AMC Spirit GT. If you know what your standard shock dimensions are (collapsed, extended, etc) this site helps.
Later!
Mr. Ed
Old Mar 31, 2018 | 05:34 PM
1948Dev's Avatar
1948Dev
We used to use that listing all the time when I was at Global West Suspension in the 90's. Especially for the parts bag numbers to get new shock mount rubber/hardware.
Most of the time for a particular length you had to get out the tape measure and do the measurements for full droop, ride height and full compression and then get in the manufacturer
listings to get the right shock. I just did this recently to put Vikings on my '48....... not too bad because you can get the specs. For Koni, not an easy task because I don't think they
publicize spec sheets for their products. They like to play the "I've got a secret" game.......
Old Mar 31, 2018 | 05:54 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'm honestly surprised that a Jag suspension would need 10" of travel?
Old Apr 1, 2018 | 02:32 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
I was going to say the same thing Ross, you would be lucky to find 10 inches of travel in an off-road shock let alone a jag shock.
Old Apr 2, 2018 | 02:04 AM
zagamuffin's Avatar
zagamuffin
lads,
the bags have that lengh of travel but ithe Irs/Ifs isnt fitted yet so havnt measured the Actual jag travel yet.
cheers
Old Apr 2, 2018 | 03:22 AM
Steve_B's Avatar
Steve_B
I get mine from Summit, they list the extended / collapsed lengths for their shocks
Old Apr 2, 2018 | 10:41 AM
Justboy's Avatar
Justboy
I think you might be in Ireland if I'm thinking of the right person? As already said you'd be lucky to get 10" of travel unless your shock was very long. I have used this company
who are very good. If they don't have what you need off the shelf they can usually make it.
AVO
Or there is this company who do a similar thing
Protech
You can get an idea of travel if you subtract open length from closed length on the custom shocks but they are meant for traditional coil/shocks. They also might be worth phoning to see if they design something for air ride.
p.s. you will be lucky to see 4.5 inches of travel on the jag IFS
BeerCan500
Aug 30, 2012 05:06 PM
SuperDuty93
Aug 27, 2011 11:56 AM
rtcalabrojr
May 15, 2010 06:30 AM
b2trausch
Oct 23, 2007 08:36 AM
plugugly
Jun 20, 2004 03:24 PM
