Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Axle flange gaskets
Old Mar 29, 2018 | 09:24 PM
shillinghillf600's Avatar
shillinghillf600
Axle flange gaskets
Hello all, I’m working on a 65 F600 and I’m looking for the rear axle flange gasket. Any sources or part numbers would be appreciated. Thanks Bill
Old Mar 29, 2018 | 09:53 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There's more than one of these puppies, so I need to know the weight capacity of the rear axle.
I need the AXLE code, stamped on the 2nd line-far right of the Warranty Plate, riveted to the left door face below the latch.
Destroked 450's Avatar
Destroked 450
Been using RTV for years on the rear axles
Old Mar 29, 2018 | 11:21 PM
shillinghillf600
Rear axle code F 7 Thanks
Old Mar 29, 2018 | 11:53 PM
NumberDummy
Rear axle code F7 Thanks
Eaton two speed rear axle with 15,000 lbs. capacity.
B4TZ-1001-A .. Axle Flange Gasket-Use with 15,000 lbs. capacity - 5 7/8" O.D. x 4 1/2" I.D. / Obsolete
MANDERBACH FORD in Temple PA has 7 = 610-929-3683.
MILLER OBSOLETE PARTS in Binghamton NY has 42 = 607-722-5371.
BOYER TRUCK PARTS in Minneapolis MN has 59 = 612-378-0460.
GREEN SALES CO. in Cincinnati OH has 158 = 800-543-4959.
Old Mar 30, 2018 | 04:32 AM
shillinghillf600
Thanks #dummy!
Old Mar 30, 2018 | 08:26 AM
252slater's Avatar
252slater
SKF 23870 comes as a kit with both gaskets and the seal. I just went through this. Good luck
Old Mar 30, 2018 | 11:53 PM
shillinghillf600
Thanks everyone!
Old Apr 1, 2018 | 09:40 AM
P.Bronner's Avatar
P.Bronner
Same here. I like Permatex Ultra-Black.
bigcrunch
Large Truck
Aug 16, 2015 08:16 AM
pinn600
Large Truck
Apr 2, 2012 05:50 AM
Sleepy_Dave
Sep 19, 2010 03:57 AM
wickedklown83
Apr 24, 2010 05:39 PM
UnfoundFord
Aug 12, 2007 09:04 PM
