4R70W to E4OD
Old Apr 2, 2018 | 11:17 AM
zenith0000's Avatar
zenith0000
Ive seen people slap a carb on and cut out the efi crap and leave the ecu for the trans and guages
Old Apr 2, 2018 | 12:35 PM
jas88's Avatar
jas88
Ive seen people slap a carb on and cut out the efi crap and leave the ecu for the trans and gauges
Not and have it actually work.
Old Apr 2, 2018 | 12:38 PM
jas88's Avatar
jas88
No, 1994/95 F150/Bronco MAF trucks were OBD-I.
You would think I would know that since my son's 1995 F150 is MAF and OBD-I. Sometimes the stuff that comes out of my fingers is disappointingly stupid. :-(
Is the trans harness different between OBD-I and OBD-II? Could he just source a correct OBD-II E4OD ECU and then use his existing trans harness from the donor truck?
Old Apr 2, 2018 | 12:43 PM
zenith0000's Avatar
zenith0000
Thats what i was thinking. Just get an OBD II E4OD ecu. That will simpler it considerably
Old Apr 2, 2018 | 12:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by zenith0000
I would like to convert my 4R70W to 4x4 being that its only got 5,000 miles on it.
That can be done. You only need two parts, the output shaft and the extension housing.
To install the output shaft you have to take EVERYTHING out of the transmission. Install the 4x4 shaft and put the transmission back together again.
Old Apr 2, 2018 | 04:49 PM
zenith0000's Avatar
zenith0000
I rebuilt that 4R70W so taking it apart is no problem to for me. But i dont have the 4x4 shaft or extension housing for a 4R70W and the E4OD from the donor has been recently rebuilt also so thats why I wanted to use it
Old Apr 2, 2018 | 05:29 PM
My4Fordtrucks's Avatar
My4Fordtrucks
That’s pretty funny. I completely understand.
The ‘94 Bronco 302 (EDIT: w/ E4OD) I had was MAF and OBD-I.
Old Apr 3, 2018 | 03:18 AM
TexasGuy001's Avatar
TexasGuy001
I've been considering a 4wd conversion for my 94 for a while. Actually thought about it on my previous 95. Both are MAF with 4R70W. I believe for pre 96 this is the only configuration that got the mass air setup. I now remember reading a post someone made years ago with a silver F150 with 4wd and a 4R70W, so they may not be very common but were produced. I agree that converting everything to and OBDII E40D configuration would be much more difficult than just getting the appropriate 4R70W components.
Old Apr 3, 2018 | 08:23 AM
jas88's Avatar
jas88
As you know, Ty, I will be converting my son's '95 F150 to 4x4 this summer. His truck is also MAF, OBD-I, and 4R70W. However, the donor truck is an '89 with AOD so I will just treat this as a conversion to manual trans as far as the ECU is concerned.
Old Apr 3, 2018 | 09:13 AM
zenith0000's Avatar
zenith0000
So will it be possible to just plug the E4OD harness in where the 4R70W plugs in with an E4OD OBDII computer?
Old Apr 3, 2018 | 09:44 AM
subford's Avatar
subford
C103F should pug in OK to C103M but the wires on the engine side of the plug may be missing wire 924 at pin #14.
Old Apr 3, 2018 | 10:12 AM
zenith0000's Avatar
zenith0000
I'll probably buy a OBDII E4OD harness then
Old Apr 3, 2018 | 11:54 PM
  #28
TexasGuy001
Sounds reasonable to me. I don't see why that wouldn't work.
frankosd
Apr 13, 2020 10:28 PM
Josrobinson
Jun 22, 2014 02:09 PM
BORDERBUM
May 22, 2014 03:12 AM
keiser blade
Sep 10, 2009 11:45 PM
radramrod2
Jan 26, 2005 10:33 AM
